Question about Microsoft Premium System for Xbox 360
How do i connect to live? - Microsoft Premium System for Xbox 360
  • 643 Answers
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
how do i connect to live? - applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Posted on Nov 09, 2010
My xbox 360 wont connect to xbox live and ive tried everthing
things you can do..... first start by connecting your 360 to the router and run a test through the system setting menu on your 360 dash board.... to do this go to system setting menu and select the network setting menu.... after selecting network setting there should be an option to test you`xbox live connection.... this is the first step in trouble shooting.... if your xbox connects to the network or router than the problem may be in the Internet connection.... after you have a connection between the xbox and the router... connect the router to the Internet and run the the test again... if you are connected to the network and the internet but still not to xbox live try doing a system update to update your system with xbox live.... after doing all of these steps you may have purchased and xbox that has been banned from xbox live and will not be able to join xbox live..... a more simple solution is that you may not have an xbox live account and simply need to set one up... this can be done through the xbox or you can go to www.xbox.com and set up a live account... you can also find FAQ's and trouble shooting steps there
Apr 22, 2010 | Microsoft Xbox 360 Console
Error code 810003c1
Error connection with Windows Live Messenger
After failing to connect to Windows Live Messenger, Below error message appears on your screen :
"The connection to Windows Live Messenger failed - The service is unavailable - Please retry later - Error Code 810003c1"
This problem is usually related to registration information for Messenger account, specifically the country of assignment.
It is probable that the connection established for an account, but may not work with another account.
How to proceed
Exit to Windows Live Messenger
Go to Windows Live Hotmail website.
Go to Identifying Windows Live ID and Password.
Click on Windows Live and select “Account”
In the page “Account Summary”, click on ("Edit your registered information").
Under Home, select your country of residence.
Then save the modification by clicking on “Register” and close Hotmail.
You can now try to connect to Windows Live Messenger.
Regards
manish
Mar 09, 2010 | Microsoft Windows Live Messanger
How to get connected xbox live with no service
xbox live requires a high speed internet connection and for you to be in a certain place that is accessible to xbox live, if you are lacking either of those either buy high speed or move?
Nov 06, 2009 | Microsoft Xbox Live 12 Month Gold...
Cannot connect to xbox live using a wireless laptop
This site has good information relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
[url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
Aug 11, 2008 | Microsoft Xbox 360 Console
I'm trying to connect to xbox live over a laptop but it wont let me connect! What's up?
This site has good guides relating to connecting your xbox 360 to xbox live wirelessly with laptop or modified router and improving xbox live NAT rating:
Jul 03, 2008 | Microsoft Xbox 360 Console
XBOX LIVE
u may need to adjust your modem/router settings check this link out
http://www.jlsnet.co.uk/index.php?page=cc_xbox
Feb 15, 2008 | Microsoft Xbox 360 Console
Xbox (not 360)
I think someone plugged an internet cable into the back of your xbox or this cable was in there already but now started to work.
If you do not want xbox live disconnect the cable or maybe change the settings to not 'search for x box live'
If you want live make sure the cable is connected to the internet and follow the instructions in the manual.
Hope that helped
please rate
Dec 28, 2007 | Microsoft Xbox Console
Connecting to xbox live failing
The xbox live board is down,so if you pass all tests except the xbox live one,this is the problem.I rang them and they said over 50% of users are having this problem.Its because so many people went on it over Christmas and the system got overloaded.They said they're working on it and it should be up and running in a week or two. ~~PS~~ I rang on the 12-1-08 so it should be up by the 20th,its not your fault,the servers down.
Dec 22, 2007 | Microsoft Xbox 360 Console
Microsoft Premium System  for Xbox 360 Logo
157 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
