Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
How do you change the channel on a motorola cls1110
  • Motorola Master
  • 1,654 Answers
Here's a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Programming instructions begin on page 26. The CLS1110 is only capable of doing one channel at a time. You can select from the programming list which frequency you want your one channel to be.
Best regards.
Posted on Nov 10, 2010
Where to purchase CLS1110 radio in Rochester, NY
The CLS1110 radio is available through businesses whose primary focus is not two-way radios. You might check Costco, Cabelas, Grainger, etc.
Also, the sister radio Motorola VL50 is nearly idential and is available at your local Motorola dealer.
Best regards.
Nov 02, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Cp200 and cls1110
If both radios are on the same bandwidth, ie. VHF or UHF, the answer is yes. They simply would need to be programmed to match one another. The CLS1110 is the limiting factor. You would need to choose a frequency from its frequency list and have it programmed into the CP200. The radio would need to be programmed by a Motorola dealer.
Best regards.
Oct 01, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How do i replace the antenna to a cls1110?
Replacing the antenna is rather easy and will take only a few minutes. Please see a short YouTube video on how to do it. Parts are available on ShopWiscomm.com Amazon or Ebay
https://www.youtube.com/watch?v=JbQn-6-xgPk Motorola CLS1110 CLS1410 Replacement Antenna Installation Instructions
Dec 02, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Will the motorola mr350r work with the motorola cs1110
  • The mr350 is a standard GMRS/FRS talk around radio and the cls1110 is a business band radio but bot operate in UHF. So if the cls1110 is programed to one of the frequencies I will list then the two will communicate. Otherwise they will not.
Here are the frequencies listed in order of channels on your radio. 1-22.
Apr 30, 2011 | Motorola MR350R Two Way Radio
How do i put my new cls1110 on prog 1 frequency 4
The CLS1110 is a one channel radio. However the one channel can be changed to another frequency and/or PL code. With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
Best regards.
Nov 16, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Frequency changing
Here is a link to the manual http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
Entering Programming Mode
Press and hold Push to Talk and Monitor for 3 seconds while turning the radio on. The
radio beeps and displays PROG, the channel number flashes, and the frequency
(indicated by FREQ) and code (indicated by CODE) display alternately.
Use the MENU and the + or - keys to change the programming. More detailed instructions are on page 28 of the manual.
Best regards.
Dec 29, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
When I tried to change the frequency on my Motorola CLS 1110, I see a lock graphic. How can I get rid of the lock so I can change the frequency. Right now it has only 1 and 2 frequency and I need 4. Thank...
To unlock (or lock) your keypad hold the menu button in for 3 seconds.
Here is a link to the user guide. The CLS1110 is a 1 channel radio. It has several frequencies built in to choose from.
Dec 08, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Is it possible to create a channel on a two way radio?
You have posted under the CLS1110 heading. If this is the radio you have here are the programming instructions: With the radio turned OFF, hold in the PTT and the MON, while turning the radio on. Continue to hold the PTT and MON until the radio stops making noise. You are then in programming2.gif mode and can use the menu button to walk through the stages of programming. Use the PTT to change the settings, and the MENU to lock it in.
The CLS1110 has 56 built-in frequencies to choose from. You cannot program in a "custom" frequency. Only choose from the list.
Sep 28, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
841 people viewed this question
Top Motorola Radio Communications Experts
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
