Question about Generation 2 Worldwide Geneva Crib
I need replacement hardware for a Generation 2 world wide 64-3151 May 2000 dothranla USA 36301 RPF991264
Need for a 1993 izuzu pickup thats not getting gas to carberator
what engine? there are like 7 world wide. is car USA
the word PICKUP is both generic and real trade mark. how do you mean that word, USA pickup 93? or some other pickup sold world wide, looks like pickup but has other names (vast)_
ill guess USA, 2.3-liter 4ZD1,
outside usa its a FASTER (and huge list of names)
the usa engine sure did have a CARB, last one was 1994 in usa,
and Isuzu made that car... ending carbs forever.
how do you know that? (NOT GETTING FUEL)
no method stated.
looking down air horn cranked (boom , eye browse burned)
or cracking lines looking at dribble.?
or see the High speed accelerator pump dead, in carb. horn viewed?
how?
CARB 101 (basic basics)
one isuzu with carb has glass float bowl lid (yah scary) does yours>?
1: fuel pressure at spec, 3.5 PSI is spec, (off SM)
2: then if that's ok , the glass in front of the FLOAT bowl shows
fuel lever there is on the line, proper. ! float level.
3: if you look in there and see lots of CRUD, bingo.
4: if dry now, or low, the float valve is gummed up or stuck closed.
5: if fuel is too high it floods.
6: if all the above is ok the carb jets are clogged with junk as all do.
end (super basics carb) we can go like this for days, on carbs.
seen all fails, of all kinds, carbs. endless. they are.
ever fix quadrajets or SU carbs, you seen lots of failures.
Mar 23, 2017 | Isuzu Cars & Trucks
I wan't to know wiring diagram for suzuki all new swift with K14B engine. Because i want to install hks fcon is
GO Get a manual of your suzuki from Best Manuals u will get all diagrams and steps to do whatsoever u want ur car it helps alot even i got one for my car :)
May 24, 2016 | Suzuki Cars & Trucks
How to fix a slow jet in your car
hello welcome to USA forum fixya.!
the swift is not sold here, (my nephew has one with 1.3L in South America now, just drove it last week. )
tiny front wheeled car sold everywhere, but USA.
why not post symptoms first.
ask for diagnosis.?
the car has no carb, or any jets.
its and EFI injected engine, sold in many size engines world wide.
many are 1.5L , M15a engines, some are VVT valve timed.
so, what's up doc?
me eating carrot......munch munch....
here is the wiki list for 2005 generation.
1.2 L I4 (petrol)
1.3 L M13A I4 (petrol)
1.5 L M15A I4 (petrol)
1.6 L M16A I4 (petrol)
1.3 L I4 (diesel)
Feb 06, 2016 | 2005 Suzuki Swift
How can I remove a power steering belt on a 1986 pontiac parisienne
triple posted, but still no engine stated.
cars have 3 or more engine, some 10 world wide, or more.
no country ? USA exports cars. too,.
here is the list , uSA
231 cu in (3.8 L) Buick V6
265 cu in (4.3 L) Pontiac V8
301 cu in (4.9 L) Pontiac V8
305 cu in (5.0 L) Chevrolet V8
350 cu in (5.7 L) Pontiac V8
350 cu in (5.7 L) Oldsmobile Diesel V8
400 cu in (6.6 L) Pontiac listed in wiki 5th generation.
truly sorry
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
short answer, loosen the tension device,
i can no point to it , lacking engine, and if it has A/C options.
Jun 21, 2014 | Cars & Trucks
07 Chevy Cobalt brake lights do not work. turn signals work, tail lights work, Cyclops brake light also works. Fuse is good. New bulbs
so 3 lamps (usa deal with cyclops)
and you say 2 fail L/R and center works?
is that true. or a typo.... ?
if never seen any car wiring go to center then left then right
in a daisy chain.
most go left , then both seperate path to center and right.
in USA, we have LHD cars, not right. side. drive.
and RHD cars are wired, backwards.
i refuse to do world wide Cobalt market look ups. no country state and all lights is different world wide as are color codes.
ok try on light at a time, put in, take out,move it 3 times.
works?
I bet all 3 are dead for brakes.
if true.
its the brake lamp switch malfing.
or cut wires ,due to trailer hitch goons. (hackers)
Oct 09, 2013 | Cars & Trucks
Suzuki swift + 2006 i change t belt to 100000km and all my ilder bearing is jam i think a have a problem with suzuki part its normal?????
old post, but Ill answer for others. with same issue, belts.
Timing.
no country stated. so.... ?
what engine.? there are 56, and many cars have 8 engines used
on one brand car.
I live in the USA< and go to to any store that sells GATES belts.
Napa is my best store,
and GATES has a full kit ,with the best belt and a new idler.
suzuki real parts , only in USA and Canada is Suzuki shutting down. (some parts sources do remain open, no all,)
your car, a Generation 2 swift
had , 5 engines offered world wide, says wiki, 1sec search
1.2 L I4 (petrol)
1.3 L I4 (petrol)
1.5 L I4 (petrol)
1.6 L I4 (petrol)
1.3 L I4 (diesel)
which might you have.???
Jan 26, 2013 | 2006 Suzuki Swift
Need replacement bowl
Depends where you are. These are the guys who sell the fans in the US (Through Amazon): Direct link; http://www.antonline.com/c_0_18317_5__3268_1_50.htm Company name: ANTonline Street address: 33 Mansell Court Suite 200 Roswell, GA 30076 USA Web site: http://www.antonline.com Customer-service phone, fax, and e-mail Phone: 877-293-9797 Fax: 770-874-0789 Email: support@antonline.com Hours: 9am-6pm Mon.-Fri. EST Also the fan is Known by the "Boston Harbor" name (same model number). If you are outside the USA, please ask again. Hope this helps :) ps the Amazon list price for the whole unit is $77, so check on replacement bowl prices before ordering - if the fan is more than a few years old, it may be better to replace completely.
Aug 22, 2007 | World Wide Sourcing (CFB5521F242WH)...
Generation 2 Worldwide Geneva Crib Logo
75 people viewed this question
Top Generation Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Generation Baby Gear Expert? Answer questions, earn points and help others
