Question about Samsung RS2578BB Side by Side Refrigerator
SAMSUNG SIDE BY SIDE RS2556
TEMP BLINKING FOR THE FRIDG SIDE. FRIDG NOT COLD AT ALL. FREEZER OK. SHOULD I SHUT OFF FOR AN HOUR OR TWO TO SEE IF IT NEEDS TO DEFROST?
Is it blinking 34???
Posted on Jun 17, 2008
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
I have a Samsung RS2555SW and the Freezer side is not working properly. It started blinking -4 so I reset it via the panel and then by unplugging it. Neither worked. This happen a month ago and I took...
Sounds very likely it is the fan , it cud be the fan is hitting some cable or ice as well , or the fan motor has had it , most of those fans r 240 volts , so any fit any
Feb 01, 2010 | Samsung RS2556 Side by Side Refrigerator
My temp willnt work on the freezer
OK, I will get the service manual and be right back. Sea Breeze
Nov 10, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Feb 06, 2008 | Samsung RS2556 Side by Side Refrigerator
The freezer light is blinking -4
according to the service manuel a blinking light indicates a sensor failure in the section in your case the freezer side but don't panic the unit has an emergency run mode which will keep things at set value till the unit is check in other words like it is now this is a complicated unit so id call for a factory authorized tech to come and check it
Jan 14, 2008 | Samsung RS2556 Side by Side Refrigerator
The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Aug 08, 2007 | Samsung RS2556 Side by Side Refrigerator
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
442 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
