Question about Husqvarna Viking 1
How to disassemble viking sewing machine and fix the timing
SOURCE: Viking sewing machine
http://www.sewusa.com/
Go here! FREE!
Posted on Feb 09, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
Posted on Jul 25, 2009
Sewtech1
  • 69 Answers
SOURCE: Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Posted on Jan 26, 2010
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
The plastic gear in the 6010 Viking is cracked and I'd like to replace it.
Have you searched the internet?
Absolute Sewing Machine Information Husqvarna Viking Service manual
Sewing Machine Viking 6000 Cam Replacement (not sure if it is the cam gear that needs replacement)
If you are unable to find instructions, perhaps you can find an independent sewing machine repair person who would be willing to do it for you.
Jun 03, 2016 | Husqvarna Sewing Machines
How do I reassemble the bobbin/rotary hook area of a Husqvarna Viking 120 sewing machine?
Just a thought check that your needle is in properly it makes a differene
May 17, 2014 | Husqvarna Viking 1
Viking 6690 will only sew in reverse what to do
The reverse mechanism has a tendency to stick in these machines. Unfortunately, putting oil on it will not make it come loose. You need to find an authorized dealer that knows your machine and they can take care of it for you. Some areas of this machine must be disassembled to be cleaned properly.
Oct 31, 2011 | Husqvarna Viking 1
My model 120 Husqvarna Viking sewing machine will not start sewing with vigor. It lugs through the first two minutes of stitching with virtually no power then very gradually picks up speed. How do I fix...
Repair manuals are available only to Husqvarna Viking authorized dealers. However, I have seen some on ebay from time to time. Sounds like your problem could be several things - binding of the internal drive shaft which may have a build up of grease and lint which unbinds as you sew, could be a faulty motor, or faulty transformer. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jan 25, 2010 | Husqvarna Viking 1
The needle in my Viking 6440 is locked in on the left side and the machine will only sew in reverse. The reverse button cannot be moved in or out.
I'm trying to find a machine similar to yours and have done much research re: the older mech viking sewing machines 6000 series. They are GREAT machines, suffering only from problems such as yours caused by the old "lube/grease" they used when it was made @ factory. In their efforts of making a "never needs oil" mech sewing machine, the grease tends to harden & freeze up the gears & cams inside the machine. You need to have it serviced @ authorized Viking shop as you have to completely disassemble the machines & gears, clean, re-lube, & re calibrate the gears... I understand this s/b ~ $175. Money well spent considering if taken care of your beauty could be sewing for another 60 yrs!
Hope this helps!
Jan 22, 2010 | Husqvarna Viking 1
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Husqvarna Viking Sewing Machine 6020 sews in reverse
It doesn't need a part for this repair. The reverse mechanism inside the machine is seized from old grease which has hardened. It should be seen by a technician so the part can be cleaned out. Don't be surprised if he finds a broken take up slide or a cracked pattern mechanism.
Get an estimate before you have any work done and ask about a warranty for the work they plan to do.It may be less expensive to buy a newer machine.
sewman7
May 02, 2009 | Husqvarna Viking 1
I have a very old viking - feed dog problem
The older 6XXX series are the best machines Viking ever made. But they have one flaw - if the button hole mechanism is not regularly serviced and used, it will eventually stick and the machine will only sew in reverse. This can also happen if you turn the knob backwards when in button hole mode.
I always tell my customers to make a few button holes every time they use the machine. This helps to keep the mechanism free and working between servicing.
Unfortunately the fix is not a DIY consumer project. It requires knowledge and expertise in disassembling the machine and re-aligning the parts. Expect to pay anywhere from $25 to $75 in addition to the regular servicing fee.
Steve P
Minneapolis
aka "The Bobbin Doctor"
Oct 05, 2008 | Husqvarna Viking 1
Husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Mar 06, 2008 | Husqvarna Viking 1
Sewing Machines Logo
738 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
