Question about Logitech Z523 2 Speakers
Crackling and hum noise - Logitech Z523 2 Speakers
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 28, 2016 | In Microwave Ovens
Why i can hear faint sound on my mixing amplifier
Depends on what sound it is. If it's a hum, then it could be a fault. If the hum is on one channel then the place to look is that channel. You can compare the good channel with the bad one for clues as to what.
If it is in both channels then you are looking at the power supply. Or something common to both channels.
Hum is most often caused by Electrolytic Capacitors.
Crackling noises are caused by resistors, or transistors, or IC's.
Jul 01, 2016 | Audio Players & Recorders
Blackberry phone wont start but makes humming noise when charging
Pull the power cell out and replace. For testing, take it to the phone store and have them run a continuity test to see if any of the other components were damegaed.
Mar 21, 2014 | RIM BlackBerry Curve 8310 Smartphone
Crackling & popping noise from one channel
Your best way to deal with this issue is to do some "hum tests" inside the unit with it on. Since only one channel is faulty and they are identical, you can use the good channel as comparrison with the bad. You simply touch with you a plastic tool or if you can your finger - not touching metal parts though - and either channel will buzz. Chances are you will come upon the faulty part and make it crackle.
Feb 26, 2013 | Audio Players & Recorders
Ac adaptor crackling thru external speakers
Allan, It sounds like you have what is called a ground loop. A ground loop can occur when two pieces of equipment are connected together through a home or buildings safety ground through the same power source. For instance, your PC is connected to a power source through the AC adapter or plug, and your external powered speakers are receiving power from the same power source. The surrounding cables as well as the AC adapter(s) can act like an antenna. This will cause a low hum or crackling that would be audible through the speakers or headphones.
You may want to try plugging all components into a power strip so they are all on the same circuit. You may also want to be sure that the AC adapter cables are not not laying or running across other electrical components plugged into a different socket.
If you get the same hum through your headphones check to see if the headphones were manufactured with shielded cabling. A shielded cable is made with a wire mesh around the outside that helps reduce electrical noise. Hope this helps a little. Thanks!
Aug 31, 2012 | HP Pavilion dv6000z Notebook
Humming noise with crackling from rear end, inability to move
that is not a good noise. you will need to remove the rear cover on the rear end I think you will find a lot of broken pieces, sounds like you need a ring and pinion gear set......SORRY
Dec 01, 2010 | 2005 Dodge Ram 1500
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Iball speakers making irritating noise
please try better speakers better ohms orhigher wattage. improper speakers not for pc's or laptop will cause the hum..
Nov 29, 2008 | Audio Players & Recorders
Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Jan 21, 2008 | Sony I/M CMT-CP1 98 FRENCH Shelf System
Logitech Z523 2 Speakers Logo
137 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
