Question about Refrigerators
GE Freezer Side Ice Dispenser
I have a Model TFX20JRBK WW GE side-by-side refrig/freezer. The thru-the-door ice dispenser often fails to allow ice cubes to go through. I can usually correct this by sticking my hand into the ice bin and moving the ice cubes around. All solenoids appear to be operating properly and outlet doors are opening. Water dispenses well and ice is crushed well (WHEN cubes drop into the blades) The cubes were initially smaller than when I bought it, 8 yrs ago, but I adjusted the water volume time to about 7 seconds and the cubes are now normal looking size. The auger turns, the dispensing door opens, but often no cubes come out till I correct it. Could the plastic wheel which dispenses the cubes be the problem? If so, what would the remedy be? Any other suggestions would be greatly appreciated - THANK YOU!
  • scott234 Jul 21, 2008
    I'm having the same issue.  I noticed that the plastic wheel you mentioned just "freewheels" and doesn't turn when I turn the auger by hand.  Is that normal?
  • 10S Jay Sep 18, 2008
    I solved the problem by replacing the auger assembly - approx. $100 with plastic case. It appears that the shaft of the auger that goes through the dispensing tumbler was no longer "fixed" in the tumbler. Sometimes it would turns the tumbler, sometimes it wouldn't. NOW, when the auger turns, the tumbler always turns with it. The problem was completely solved. There may have been another solution, but this one worked great.
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Posted on Sep 18, 2008
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
Posted on May 23, 2009
Water not coming out from water dispenser
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a heater which is easily installed , to keep this from happening again pt # WR49X10173
May 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Feb 12, 2010 | GE Refrigerators
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
347 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
