Question about Hitachi 43FDX15B 43" Rear Projection Television
The picture is kinda wavy and the three different colors are off set
  • Hitachi Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Posted on Nov 09, 2010
Testimonial: "you people are awsome thanks so much!"
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluiThe picture is kinda wavy - 578ba6c.jpgbr />
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Posted on Jan 30, 2011
    Brigadier General:
  • 8,909 Answers
That sounds like you have a power supply fault and the convergeance panel is not getting the correct supply voltage.
Check for open circuit fuseable links.
Hope this helps.
The picture is changing colors and kinda of bending at the edges
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
Oct 16, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 07, 2010 | Televison & Video
Kinda blurry
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Philips Televison & Video
Wavy picture on top and bottom
*Screen Looks 3-D
*Colors wont align
Mar 29, 2010 | Sony KP-53HS30 53" Rear Projection...
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Wavy picture with blue and purple color.
*Screen Looks 3-D
*Colors wont align
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Wavy picture at bottom half of screen looks like two different colors, top half convergence looks good bottom half of pictute looksbad . Can it be vertical coil on two piture tubes not being drivendue to...
*Screen Looks 3-D
*Colors wont align
Oct 26, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Compaq Presario sr1720nx has wavy video. You can see everything okay it's just that the video is wavy and kinda taxing on your eyes. It does this with every monitor I hook it up to. I've also tried a...
Is it wavy all the time or just when windows is booted up? Try booting up in low res mode or safe mode and see if the problem continues. What is the monitor refresh rate set at? Try lowering the refersh rate. The on board video/video card may be going bad. Lowering the refresh rate may reduce the wavy picture. If it has a video card you could try installing a different card. If it has onboard video try installing a video card. Make sure you drivers are up to date.
Sep 08, 2009 | Compaq Computers & Internet
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
280 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
