Question about HP DeskJet F380 All-In-One Printer
Orange flashing light despite replacing color ink
  • HP Master
  • 7,733 Answers
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Why is the ink light flashing orange? I just printed a test page and both black and white colors printed.
Hi Linda,
Orange light blinks if one of more cartridge is empty. Check which one is empty and replace it
Regards,
Sean
Mar 02, 2013 | HP Deskjet F335 All-In-One InkJet Printer
My xerox Phaser 8550 has steady orange light and a message "Low Ink"
it may be the cartridges are dried up from being stored incorrectly take them back get new ones to rule that out first !! Hope this helps!!
Jul 21, 2017 | Xerox Phaser 8500/DN Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Orange cartridge light is flashing. I know the black cartridge is empty, but the colour cartridge is o.k. Why can't I print in colour?
Inkjet printers use a combination of inks to produce colors; while you may not realize it, your printer uses black ink to print colors as well, to darken the hue of a color. Otherwise, it would be limited to very "bright" colors. Replace the black cartridge, you will be fine.
Mar 05, 2010 | HP PSC 1350 All-In-One Thermal Printer
Changing ink cartridges
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
Oct 15, 2008 | HP DeskJet 990cxi InkJet Printer
Canon i950 flashing orange green orange green
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Aug 22, 2008 | Canon i950 InkJet Photo Printer
HP DeskJet 722c orange ink light flashing
Try changing the color cartridge. Also it is a good idea to clean the electrical contacts if it looks dirty.Use slightly damp(use water only) q-tips .
Hope this helps
Mar 27, 2008 | HP DeskJet 722c InkJet Printer
Deskjet 4163
Hi , the printer are warn that the ink is almost empty , try reserve new and genuine ink deskjet.
Feb 23, 2008 | Office Equipment & Supplies
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
Seeker5211
Seeker5211
