Question about Zanussi W1042W Front Load Washer
Machine does not spin. The drum still turns on the drying function but when it gets to the spin cycle it just turns a few times and stops. The clothes come out wet. There are not bad sounds of any sort.
  • 144 Answers
A lot of machines have motors with carbon brushes that wear out, this is not usually expensive , if machine is several years old this would be my first check, and the fault you describe i have had. Cost me 10 pounds for parts took me 30mins to fix. you would need to know a little bit about this kind of job so I would ask a friendy repair man,
pete
Posted on Nov 09, 2010
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Hec 1050w
oh hec its a hec
have you cleaned the filter
Feb 03, 2014 | Washing Machines
Spin dry
I have washer Model # XQB60-91BF It do all functions eccept spinning when it comes on spinning drum does't rotate. I replaced drain pump but does't spin. Can you guide me about trouble.
Thanks. email: khansaleemuddin@hotmail.com
Jan 20, 2013 | Haier XQB60-91BF 1.92 cu.ft. Portable...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Wash cycle and spin
you need to check a simple button called " no spin" may you will see it marked "aspiral shap" and has "x" over
good work !
Jul 05, 2009 | Zanussi ZWF1430W Front Load Washer
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Zanussi W1042W Front Load Washer Logo
169 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
