Question about Lucent PARTNER18 Corded Phone
Need to program the clock? - Lucent PARTNER18 Corded Phone
    President:
  • Lucent Master
  • 860 Answers
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Posted on Nov 09, 2010
I need owners manual to program RCA RC140-A alarm clock
Hello
Send your Emai Address to me. I've the user manual for your RCA RC 140. I actually do not remember, from which site did I downloaded it. I can't send it to you by this window, as it does not allow me to upload PDF fiels by it. If you send your Email ID, I'll send a copy of it to you by return mail. OK.
Nov 27, 2011 | RCA Radio Alarm Clock
How do I change the time one hour ahead for an RP5430A model clock radio?
Slide the Wake 1/Wake2/Clock switch to the Clock position. Then press the forward button to advance the clock by the needed amount of time. Then slide the switch back to the side with the key icon.
If you set the DST switch to ON, you can move the time zone switch to one time zone further east for a few weeks until the DST change in the program takes effect. Then move the time zone switch back to your current time zone. (Repeat this in the fall to correct for the later change in DST again). The exact length of time between when DST starts and ends versus when the clock will change the program will depend on when the clock was manufactured. Clocks built after July 2006 should have the correct DST programs. Clocks from earlier have a much shorter period of DST (April through Oct).
I hope this helps.
Mar 13, 2011 | RCA RP5430 Clock Radio
HOW DO I SET CLOCK
1 Press STANDBY/ON to turn off the unit, if it is turned on.
The clock flashes on the display window.
2 Press and hold PROGRAM/CLOCK SET for more than 2 seconds.
The hour digits start flashing.
AM
3 Press the CD forward or CD back button (track skip buttons) to adjust the hour, then press PROGRAM/CLOCK SET.
The minute digits start flashing.
PM
4 Press CD forward or CD back button (track skip buttons) to adjust the minutes, then press PROGRAM/CLOCK SET.
I hope this helps.. !
If you need more info have a look here for the manual which is in pdf format:
The clock information is on page 10
JVC RC-EX25 manual
Regards
Mike
Oct 12, 2010 | JVC RC-EX25 Radio/Cassette/CD Boombox
Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Mercedes s500 intrument clock
hello,good day,no resetting or programming is needed,if your clock in cluster is really defective,replaces with new one or second hand as long it's working,ty
May 28, 2009 | 1997 Mercedes-Benz C-Class
I need a program of cpu scheduling using C++ please help me out it consit of FCFS,SJF and RR..
// crt_clock.c // This example prompts for how long // the program is to run and then continuously // displays the elapsed time for that period. // #include <stdio.h> #include <stdlib.h> #include <time.h> void sleep( clock_t wait ); int main( void ) { long i = 6000000L; clock_t start, finish; double duration; // Delay for a specified time. printf( "Delay for three seconds\n" ); sleep( (clock_t)3 * CLOCKS_PER_SEC ); printf( "Done!\n" ); // Measure the duration of an event. printf( "Time to do %ld empty loops is ", i ); start = clock(); while( i-- ) ; finish = clock(); duration = (double)(finish - start) / CLOCKS_PER_SEC; printf( "%2.1f seconds\n", duration ); } // Pauses for a specified number of milliseconds. void sleep( clock_t wait ) { clock_t goal; goal = wait + clock(); while( goal > clock() ) ; }
Mar 22, 2009 | Computers & Internet
I need help
On the front of the system, press and hold Clock button until the hour flashes. Then press the Digital tuning arrows for up or down. Watch the display for AM or PM. Stop on your hour. Press and hold the Clock button again til the minutes flash. Press the Digital Tuning arrows again for up or down. Immediately press Program Set button under the Digital Tuning arrows to set the program in. If you do not press Prog Set soon enough, you will have to do the whole thing all over.
Apr 22, 2008 | RCA 100-Watt Stereo System With 5-CD...
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Lucent PARTNER18 Corded Phone Logo
173 people viewed this question
Top Lucent Lands Phones Experts
Marvin
Marvin
vince
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
