Question about Brother MFC-640CW All-In-One InkJet Printer
IS THERE AN 'ON/OFF' SWITCH ON THE MACHINE? - Brother MFC-640CW All-In-One InkJet Printer
No but there is a Power Save button to the left of the Stop/Exit button just press and hold until the LCD says Shutting Down...
Posted on Dec 17, 2010
Machine does not power up
The fuse is located in a little black box underneath the base of the machine, but it is not an easy job to take the box out, disassemble it, replace the fuse, and then reassemble the whole machine. I suggest you take it to a service center.
Aug 31, 2008 | Janome Memory Craft 4000 Sewing Machine
How to install new switch?
Remove the back cover of the machine by removing the 2 screws on the back.. Pull the back cover off, and you would have access to the power switch on the back of the machine.
Purchase a switch click here.
SWITCH NE03 028
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
May 27, 2015 | Saeco Incanto Classic Espresso Machine
C44 call for service problems
Hello
Please switch off the machine. While holding down 0+8 buttons please switch on the machine.
When the machine is in TEST MODE, input 400 and press the start button, press the 0 button and
then press the enter tab on the display.
Switch off the machine wait 1 minute and then switch on the machine.
If the error code reappears the thermistors and thermo fuses need to be replaced in the fuser section.
I hope that this sorts out the machine.
Regards
Apr 15, 2011 | Toshiba e-Studio 350 Copier
I have got a westpoint washing machine XQG50-604 the water switch is faulty but the machine is working it doenst pour water on the machine at all.rose e-mail:rntuli@uj.ac.za
Hi
I have a Westpoint front loader washing machine, model number XQG50-604. The power button got stuck, opened machine up and find the power switch burnt out. Where is Johannesburg in South Africa can I get a new switch please? Also can you advise how to remove old switch and to replace the new switch.
Regards
Juanita
Feb 15, 2011 | Washing Machines
Spin Safety Switch has broken where it screws into the machine
If you take a one inch paint scraper and insert it about three inches from the edge of the washing machine top and push on a small spring clip. At the same time lift up on the washing machine top. You can now access the lid switch.There are two screws holding the switch in place located inside the lid.
You can take the switch into any appliance service store and they can help you get a new switch.
Dec 28, 2009 | Kenmore 20722
Top loading machine will not empty water or spin
Hi, check your fuse or circuit breaker in your house panel, check make sure there's power in your washer receptacle,(outlet,socket). if there's power in washer receptacle, check machine lid switch first, lift (open) top of machine, look under area covered by lid, switch should be located there, you did not say what model or make of machine, i could be more accurate in helping you find lid switch. check lid switch first, if lid switch o/k, you will have to make more checks, check for breakage, damages machine plug, check from plug all the way to where it is connected inside of machine, check your timer, any printed circuit boards , check machine water level switches, and all other switches, until you find (faulty one) problem, also check motor, and motor capacitor. if you have to reach that far. but first check simple, basic things, make sure power to machine, check lid switch., always remember, disconnect power before doing any repairs, let me know what happened., you can empty your machine by lowering drain hose close to floor. by gravity, use bucket, or something to collect water from machine.. good luck.
Aug 15, 2009 | Washing Machines
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Brother MFC-640CW All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
