Question about Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor
Goes black - Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor
  • Louis Ebert Nov 09, 2010
    dentalb, Tell me if it is just "black" or is it "blank n black" when connected to fully booted pc with WIN desktop as default screen. Use bright flashlight 1 inch from screen to try and see very faint image of desktop. If see nothing= smps dc sources in full shutdown mode!! If see desktop image and icons= Partial shutdowm mode. Let me know with reply what you see or don't see. 12fixlouie
  • 11,361 Answers
Try it with another PC to make sure it is not the PC problem.
Otherwise, look inside for bad caps first.
Boards: http://www.lcdrepair.us/E2208WFPt-inverter-power.html
http://www.lcdrepair.us/SP2208WFPt-inverter-power.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Nov 10, 2010
What colors are the Speaker Wired for a 1993 gmc 1500 van
    1. OK,GMC/GM are wired as such. White/Black wire, front left -[neg] White, front left +[pos]. Grey/Black wire, front rt -[neg], Grey wire, front rt +[pos]....Green/Black wire, left rear [neg], Green, left rear [pos]....Violet/,Black , Rt rear [neg],...Violet, Rt.rear [pos]........You will also have a Blue/Red wire that goes to antenna. ..A Blue wire for Power Remote....Red goes to IGNITION.....Yellow goes to Battery[for clock].....And finally a Black goes to Ground.......I hope that you have good luck and everything works out for you. `
Sep 07, 2015 | GMC Cars & Trucks
Pass and seymour ws 3000 Hooking up to basement I have a white, black and copper wire. On the switch I have a green read and black wire. Black to black. green to ground Red to ?
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Oct 23, 2010 | Pass & Seymour #DDH16PBK White Fan Control...
I am trying to install utilitech 7 day in-wall timer. Their are 3 switches in box controlling different fixtures. The old switch had black connected and a black looped to the next switch. How do I connect...
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Sep 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have one negative wire that goes to the back i
an aftermarket radio?
Black - Ground
Red - Accessory (+)
Yellow - Constant (+)
If it's red/black, it's accessory (+)
Nov 01, 2009 | 1995 Mitsubishi Eclipse
The yellow wire goes into a black box. A yellow
Yes, the black wire goes to ground.
Yellow - Constant 12v.
Black - Ground (MUST hook up! NEVER let your antenna pull the ground)
Red - Switched 12v through the ignition
Oct 25, 2009 | Blaupunkt Ontario CD85
I have a black, white, red and a bare wire in the ceiling. the fan has black, white and blue wires. what goes with what
black goes to black. white goes to white. red goes to blue. there should also be a green wire attached to the fan near where the other wires come out, if you do it attaches to the bare wire
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Aug 31, 2009 | Westinghouse Fans Indoor Ceiling Fans
2001 Chevrolet Impala 3.8 fuel pump wiring diagram
The wires should be grey, orange and black, purple, and a black wire. The purple goes to purple, grey to gray. The orange and black goes to the small black wire on your car harness and the black goes to the bigger black.
Apr 30, 2009 | 2001 Chevrolet Impala
Trying to hardwire my mini fridge in my popup. I have a blue and a gray wire coming from the condenser and a black and a white wire coming from the thermostat control, and a white and a black wire coming...
ok the black wire from the powersource goes to the (-)negative terminal in the converter, the white wire goes to the (+) positive.
From the converter the white wire goes to the white wire on the termostat.
the thermostat black wire goes to the grey wire on the condenser
the blue wire on the condenser goes to the black wire on the Conveter.
Mar 27, 2009 | Refrigerators
Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor Logo
234 people viewed this question
Alun Cox
