Question about Toshiba Satellite M55-S3291 Notebook
Battery is not charging. I replace the Battery and It did not make any difference
    Brigadier General:
  • 8,909 Answers
I suspect a mother board problem. Possibly a fuseable link or unfortunately the DC-DC convertor charger.
Hope it is just a fuseable link but I have my doubts.
Posted on Nov 09, 2010
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
I pad will not charge
it's not that difficult. There aren't that many solutions...either it's the battery, the charger, or the power source. :-)
Batteries stop charging after a while when they get old. One way to delay this is to NOT leave them plugged into the charging system after they are charged up...get them charged, and then unplug. The longer you leave it in, the more damage you do to the battery.
I would try changing the battery first. If it's not used up, it will be eventually, so it's never wasted money. If it doesn't charge with a new battery in it, take a look at the charger. (try a different outlet first, and try your adapter directly into the wall, not a surge protector/power strip.)
Sep 01, 2014 | Apple iPad 2 Wifi 16GB
I have an acer 7741z-4433. I've fixed it many times. One day the battery just stopped charging. So I tried swapping the ram, replacing the charge plug, replacing the battery, starting up without the usb...
The match is critical. Look for the values such as AMPERAGE in Milliamps and Proper Voltage as specified by the manufacturer. Failuer to make a pure match could burn up the Motherboard.
May 09, 2014 | Computers & Internet
No battery detected
Try a different known working battery and give it a while to try and charge up. If its not charging try a different AC Adapter. If the battery is still not charging then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | ASUS Eee Computers & Internet
2600 charging pro
What do you mean by 2600 charging pro? Are you having a problem charging the phone? If you do, the first thing that you need to do is to borrow a known working charger to see if the problem is the charger or the battery. If same problem occur, try to use different (known working) battery and see if the battery will charge.
If the different battery charged, then you need to replace the old one. But if not, then the problem is that there are some internal components that needs to be replaced.
Bringing the phone to the nearest Nokia care center would be the best thing to do, after isolating the problem.
Thank you and good luck!
Jun 17, 2010 | Nokia 2600
Phone won't charge or hold a charge - tried 3 different chargers and a new battery. Cleaned all connection points with alcohol. LG Vue
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
Jun 02, 2010 | LG Vu CU920 Cellular Phone
After charged battery,camera says battery is not fully charged then camera can't turn on.
so it means the battery might be old and not holding charge. or else some defect in battery charger may let your battery not charged at all. SO try using some other same type battery to your camera and try charging with some other different charger. Find out which one is having problem and replace them
Thanks
Apr 10, 2010 | Samsung Cameras
Blackberry model 9530 battery wont charge
You may want to try a different battery or even try a different charger. If that doesnt work you will need to contact your service provider for replacement options.
Mar 03, 2010 | Cell Phones
The battery is not charging
Normally, one of 3 causes.
  1. Dead Battery
  2. Bad connection of battery interface on Motherboard.
  3. The AC Adapter sensing pin (In the center of the plug) is damaged (If the system cannot sense the AC adapter, the charging circuit is disabled.)
Troubleshooting:
  1. Try a different AC adapter (Any Dell D-Series system adapter is interchangable)
  2. If no difference, then next is replace the battery.  (The battery on a portable is a consumable item, and the battery life is generally 300 to 500 recharge/discharge cycles  around 18 months)
  3. If no change with battery or AC adapter, then the failure is the charging circuit of the motherboard.
Mar 25, 2009 | Dell Vostro 1500 Notebook
Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Nov 15, 2007 | Motorola Mobility MD761 Cordless Phone
Toshiba Satellite M55-S3291 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
