My Fujitsu loptop has no power ligth,,even i connect the power cable it does not turn on
    Brigadier General:
  • 8,909 Answers
There are a couple of components that is possibly could be, the first is the power socket itself. They have a habit of coming away from the board or physically falling to bits. There is a fuseable link that is designed to go open circuit if the incorrect voltage is applied or indeed if the power supply on the mother board goes faulty.
Hope that enlightens you.
Posted on Nov 09, 2010
Code EF 5120c
"EF error" in Fujitsu fi-5120c scanner refers to Background changeover unit failure. This error is detected in initial checking at power on.
Probable causes:
- Defective Control PCA
- Insulation material damage of BW motor cable or the damage of the wire in the motor.
Check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2.Are the cables between the Control PCA and the BW motor damaged? Or are the connectors connected correctly? Confirm the position of the BW motor and check the cables.
3.Is the CCD cable F or B damaged? Or are the connectors connected correctly?
If the above information doesn't help, then you are recommended to visit the nearest Fujitsu service center for assistance.
Thanks & regards,
ScanCare
Mar 03, 2014 | Fujitsu fi-5750C Flatbed Scanner
I want to format loptop acer aspire one d257
go ahead , you do have my permission.
please state a question,
how?
why?
what, where, when, ? a question.
Oct 02, 2013 | Fujitsu Siemens Fujitsu Lifebook Loptop...
Cant play cityville
Lucky you? TBH... Check if you have admin settings... latest java/browser settings...and really... there's better to play.
Oct 18, 2012 | Fujitsu Siemens Fujitsu Lifebook Loptop...
97 cad turn signal lift side and brake not working **** right is working
The problem could be in one fuse, bad ligth bulb, bad combination switch wich is the turn signal lever siwtch, or the combination of all this. Is the front left turn signal working, in order to find out if the turn signal switch is working check for power at the the cable in the corredpondent connector that way you eliminate the posibilty of the turn signal sitch if you have power at the connector also do the same at the stop ligth if there is no power you have problaby bad fuse, hope this help tou out.
May 13, 2012 | Cars & Trucks
My Toshiba power light blinks only when I try power on. The ligth blinks 5 times, 2 times and 5 times again. The batery light turn off after power on. When i connect the power cord, the power ligth is...
you should check this thread out http://www.hardwareanalysis.com/content/topic/51345/
also if you need to convert from binary to hex use this link
http://easycalculation.com/hex-converter.php
Mar 21, 2011 | Toshiba Satellite 2400-S251 Notebook
I have fujitsu 4120c and it doesnot work,it have error 8.can anybody help me
Error code 8 means the SCSI fuse is blown off. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable
- Other SCSI device malfunction
Check if the SCSI cable or other SCSI devices connected to the scanner cause this error.The scanner can work even after this error occurs.
If the issue persists, you may have to contact Authorised Fujitsu Engineer to rectify the error.
Hope the above information is helpful.
Thank you for contacting Fixya.
Regards,
TechSatya
tech.satya@gmail.com
Nov 13, 2010 | Fujitsu fi-4120C Path-Through Scanner
We are not able to get our Fujitsu fi-5120C out of status 8. We've turned it on/off unplugged it changed one of the pads (as it was bent). We left it alone for a day and it's still not working. Do you have...
Thank you for contacting FixYa.
Please clarify if the error is E8 or some different error. E8 error indicates that SCSI fuse is blown. When 5V, 3.3V fuse is blown, the scanner does not turn on and E8 error is displayed. Check the SCSI fuse status. The SCSI fuse is located in the Control PCA marked as TH2. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable. #Check the SCSI cable status.
- Other SCSI device malfunction. #Check the SCSI device.
1. Does the same symptom occur after turning OFF and ON the scanner?
To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check if the SCSI cable or other SCSI devices connected to the scanner cause this error. The scanner can work even after this error occurs. However, to remove this error you may have to replace the Control PCA.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Microsoft Word - P1PA03289-B30X6_03.doc matsubara 11.9999 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Jul 15, 2010 | Fujitsu fi-5120C
My laptop doesn't turn on and the red indicator of the battery
check the power settings and make sure that the battery and power cable settings are on when plugged in. Also sometimes a battery needs to be installed to do this. If the power adapter is working then all should be fine.
Aug 26, 2009 | Fujitsu Siemens LifeBook C1020 Notebook
Missing operating system
HELLO THERE:
First boot into bios and see if the harddrive is being recognised and if it is make sure that the drive is part of the boot sequence if it is you might have to reformat the drive or just reinstall the operating system ok? best regards mike
Aug 17, 2009 | Fujitsu Siemens Computers & Internet
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Jan 04, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
David Payne
David Payne
