Question about Microsoft Windows Vista Ultimate Edition
Message: "check USB connection" for WMDC
Cell phone is connected to laptop via USB connection. Cannot connect to the internet via internet sharing because message "check USB connection" shows up on cell phone and laptop.
  • rrtgcd Jun 17, 2008
    Guess I need to be more specific. Our wireless phone is through Qwest here in Utah and is a Mogul by HTC. I have downloaded the windows mobile device through www.microsoft.com/windowsmobile/activesync. I have already checked to see that the USB connection is on in the settings on the Mogul. We have talked to Qwest (our phone company) and they can't do anything. My laptop is a Toshiba with the Vista program and I spent over 45 minutes with a Toshiba tech. who went through all the components on the laptop and says everything is in order.
    I desperately need to be able to connect my laptop to the internet for a class I teach in a building that does not have an internet provider so I must use internet sharing through the wireless phone.
    I have tried everything I can think of, including searching the internet for solutions, and hope you can help me!
  • Anonymous Mar 14, 2014
    The menu of wifi availability does not show up on the Connection page
    Novelist:
    Scholar:
  • 149 Answers
Is this your first time attempting to opperate one off of the other? Also, most of the time it requires a special packages from your cell phone provider in order to opperate the internet off of your cell phone. Have you already checked into this with your provider? I'm unsure of the model of your cell phone in order to check the situation further.
Let us know more details if you can otherwise get back to us on the provider situation.
Thanks for your post!
Posted on Jun 16, 2008
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How do i use the internet connectivity of my computer to browse on my mobile when connected to my ipaq instead of gprs of the phone
Just connect it through ActiveSync (XP) or WMDC (Vista and 7), through either a USB cable or a bluetooth connection. Then, make a partneship between both devices. Your computer's internet connection should become available on your phone.
Hope it works for you.
Regards, Carlos
May 24, 2010 | HP iPAQ 914c Business Messenger - Windows...
Connect to internet?
This answer assumes that the reader is already using their SD slot and wish to use another way to connect to the internet. I'm going to show you how to connect a USB Bluetooth dongle using the Toshiba e350 USB host cable. After that you can choose to share a computer internet connection via ActiveSync/WMDC or use BT DUN and a wireless phone with existing internet plan.
Windows based PC software (only needed for ActiveSync based internet sharing):
ActiveSync or WMDC
Toshiba PC Bluetooth stack 7.10.04 (or latest version for your operating system, I'm using Windows 7)
PC Hardware:
Super Mini Bluetooth 2.0 Adapter Dongle (mine was VID 0A12 PID 0001 Broadcom BCM2045 "CSR" based)
WM2003 PPC software:
Zeno USB Host Drivers v6.0a
Toshiba PDA Bluetooth stack 4.01 (filename bltstk-401-en.zip)
WM2003 registry editor (TaskMgrv2.9_WM2003SE.zip is a free task manager and registry editor, very cool)
Opera Mobile 8.65 (optional)
WM2003 PPC Hardware:
Toshiba USB host cable
2 or 4Gig SD card (for e350)
I'm going to target a Windows 7 PC with USB Bluetooth adapter, Windows Mobile Device Cener (WMDC), and an already partnered and synced Toshiba e350/355. The reader should already have a 2Gig SD card in the e350; remember WM2003 doesn't support SDHC. Any software to be installed onto the device should be done through ActiveSync Add/Remove and should not be installed to the default internal memory, but instead to the SD card.
Let's start by loading the e350 software. Install the Zeno Host drivers, followed by the Toshiba 4.01 stack. There is a newer version of this stack but it didn't work for me, so find the older bltstk-401-en.zip. The registry editor is needed for ActiveSync internet connection sharing but optional for BlueTooth Dial-up Networking (BT DUN). I'd recommend installing Opera Mobile as well. Be sure to press the reset button on the back of the e350 when done. You may now connect the USB host cable with Bluetooth adapter.
On the Windows PC connect your Bluetooth adapter and install the Toshiba PC bluetooth stack. Power up the e350 and, after a short time, there should be a wireless icon in the lower right hand corner of the main window. Back to the Windows PC, double click the Bluetooth icon in the task tray and you should be prompted to create a new connection. After awhile it should recognize your Pocket PC. If at any time you are prompted to insert a password for secure connectivity, write down a number (preferably 8 or more digits) and type it in. It will probably ask on the Windows PC first but once you continue immediately check your e350 since it will now prompt for the same password. Once it has been entered in both devices they are now "paired".
Tap the wireless icon on Pocket PC then Bluetooth Settings. Tap the magnifying glass to search for connections, your PC should already be listed as a remote device. Tap and hold over the name of your PC in the upper portion of the window and select Update Service. At least one COM port should be listed in the lower window. Tap and hold over it's name, then tap connection registration.
On the Windows PC open WMDC and select Connection Settings. Change the "Allow connections to one of the following:" drop down to the COM port listed on your device and be sure it's checked. The other settings should be default.
On the Pocket PC tap ok to close Bluetooth settings then tap Start > Programs > Bluetooth Folder > Bluetooth Connection. This will initiate an ActiveSync session and, if everything has gone well, it should connect, perform a sync then immediately disconnect. I have a problem with the immediately disconnect part, that's where the registry editor comes in. Using your preferred registry editor locate the HKEY_LOCAL_MACHINE\SOFTWARE\TOSHIBA\Bluetooth\DeviceProperty\Mode\ActiveSync\AutoDisconnect key. It's default value shoule be 1 but we want to change it to 0 thereby preventing ActiveSync from disconnecting after it sucessfully syncs.
With that done you'll probably need to reset the e350 again. At this point, because ActiveSync is set to share the computer internet connection by default, the next time you connect you should have internet access. Open your preferred web browser and check. When you are done with the internet, tap Start > ActiveSync and the Stop button. In Windows 7 as long as I'm connected I can see the Pocket PC in Windows Explorer as if it were an external drive. This makes it very easy to copy files back and forth wirelessly. Initially I set up a bridged PAN connection but, to be honest, ActiveSync works much better all around.
For BT DUN you'll need a properly configured and enabled Cell Phone with bluetooth DUN capabilities. Simply make the phone "visible" and search for it as you did the Windows PC. Pair with the phone, Update Service and register Dial-Up Networking. Tap Start > Settings > Connections tab > Connections > Add a new modem connection (Tasks tab). Enter a name for the connection and choose Bluetooth Card as the modem, then set the dial-up number, User Name, and Password from your Cell Provider. On the Advanced tab (next to Tasks tab) you may want to tap Select Networks to verify "Programs that automatically connect to the Internet should connect using:" My ISP.
You can set up ActiveSync Internet sharing along side BT DUN. When ActiveSync is connected it will automatically be the source internet connection. When disconnected, the e350 will automatically attempt to use the BT DUN connection instead.
Why not use the default Microsoft BT stack on the PC? It doesn't publish any real services, just a COM port that I never got to work. The Toshiba BT stack does have a 30 day warning so you might need to fix that.
For me the total cost of setup was about $30. The host cable was $15, the SD card $10, and the USB BT dongles were $2 apiece.
Nov 03, 2009 | Toshiba e350 Pocket PC
Request For Driver
If you running Win XP first install ActiveSync 4.5 if Vista then you need WMDC 6.1. Install one of these depends on your OS and then connect your phone...
Oct 08, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Connect to the internet on pc via cell phone
Easy, From the start menu - select programs - then select internet sharing. You have to connect to the internet from your phone and not from your computer.And make sure it's on active sync. I tried forever to connect using my laptop ... felt real stupid when i realized one has to connect from the phone. And check if your Mobile Device Centre settings are ticked of correctly.
Jun 18, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Connecting internet through tytn II
You need to install Activesync on your Laptop.
Then connect the device via USB. Once connected open the Comm manager, then you can select "Internet Sharing"
Select USB, and the network connection you want to use, then hit the connect button. You should see the laptop pick up and get an IP from the new connection.
Then you will be connected via your active network connection from the phone :)
Jun 16, 2009 | HTC TyTN Smartphone
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Sansung i780 to be used as a USB modem
(I) 1)First pair the PC and your phone of course 2)After pairing, meaning the phone and the pc sees each other, go to your phone and look for the icon "internet sharing". 3)Choose bluetooth pan as you pc connection then press connect. So now your phone is on data connection via gprs, 3g or 3g+ 4) Then go to your pc now and go to My bluetooth places search for Network Access Point and enable it. It will turn green with arrows, meaning it has established a connection.TADA! Now you have internet connection using your i780s
(II) Do you have in your programs or settings a icon called Internet Sharing?
If so please connect to active sync first and then select the internet sharing icon.
Active sync will disconnect and your laptop will start using your phone as the modem.
Wuth
Jul 01, 2008 | Cell Phones
Microsoft Windows Vista Ultimate Edition Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
