Question about Honda 2500 PSI Gas Pressure Washer
We have a Honda GCV 190 gas pressure washer. It starts up okay and runs for 20-45 seconds and then stops. We have changed bot the gasoline and the oil but run into the same problem.
  • 57 Answers
Check that the fuel tap is on
Posted on Dec 19, 2010
I have a ryobi pressure washer with the honda gcv 190 and it wont start i got fuel and spark and the switch is on it just dont want to start
Is this a brand new unit or one that you've had awhile? If one you've owned awhile, when is the last time you used it? Did you use a fuel stabilizer or drain the tank and let the engine run until it stalled?
One thing you might try would be to remove the spark plug and give a little spray of carb cleaner in to the plug hole, then reinstall the plug and try to start it. If there's just not enough vacuum to get fuel to the cylinder, getting the engine to fire off the cleaner may provide enough oomph to get the engine started and running.
Oct 08, 2016 | Garden
I need a Honda GCV 190 operation manual that is on a Ryobi 3100 psi power washer
Please click on the link for the operators manual for your engine a Honds GCV190
Hope this helps
Brad
http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X31Z8B0240.pdf
Jul 29, 2014 | Garden
Honda gcv 190
If it begins to catch then you definitely have ignition. Try replacing the plug with same type. If same result, the main jet in carburetor is clogged or the needle valve is stuck and not allowing fuel to enter into motor.
Mar 29, 2014 | Garden
Oil runs out under flywheel when motor starts honda GCV 160
Your top seal on the mower motor is faulty...replace with new seal...
Mar 25, 2013 | Homelite For Husky - Pressure Washer Pump...
Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
May 23, 2010 | Honda 8 HP Engine
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
Honda 2500 PSI Gas Pressure Washer Logo
1,822 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
