Question about E-Machines eMachines Desktop PC
I have windows 2011 update. Can I delete that and go back to Windows 2009
    Brigadier General:
  • 8,909 Answers
You cannot delete it, you may be able to uninstall it.
Go to control panel and select Programmes and features. If it is listed you can uninstall it.
Hope this helps.
Posted on Nov 09, 2010
NEED TO REMOVE DOOR PANEL ON A 2004 CHEVY AVEO
Click the link below:-----Door Panel Removal?
How to remove the door panel to install a new window regulator?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
Hummer H2 Door Panel Removal? http://technoanswers.blogspot.in/2012/07/hummer-h2-door-panel-removal.html Hummer H2: How to remove Front Door panel? http://www.howtobyme.blogspot.com/2012/07/hummer-h2-how-to-remove-front-door.html 2009 Hummer H2 Door Panel Removal http://schematicsdiagram.blogspot.in/2012/07/2009-hummer-h2-door-panel-removal.html
how to remove window motor on driver side door panel?
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
Keep updated for more help.
Nov 19, 2012 | Cars & Trucks
Tip
Tuneup utilities prefetch data deleted windows 7 slow
Basically, the prefetcher is a Windows component that speeds up the boot process and start times of programs by prefetching data.
I recommend you never delete the prefetch data.
If you or another program delete prefetch data or the folder, this can slow the computer down until the prefetch data is rebuilt. Windows rebuilds this each time on reboot and during program start ups.
If you are using a cleanup utility, turn off any options that delete prefetch data. In CCleaner, this option is unchecked automatically. TuneUp 10 does not have an option for prefetch data and does not seem to delete this data. You may receive a message when using the program that states, "prefetch data deleted" which is informing you the prefetch is empty.
-G33k
keywords
Title: tuneup utilities prefetch data deleted windows 7 slow
tuneup 10 prefetch, windows prefetch, windows 7 prefetch, windows 7 slow prefetch, windows tuneup prefetch delete, prefetch deleted, prefetch, prefetch data deleted, how to tune up utility prefetch data, prefetch data deleted tuneup utilities 2011, tuneup 2011 prefetch data deleted
on May 25, 2011 | Microsoft Windows 7 Ultimate for PC
Pontiac G6 power window won't work
For all types of power window problem and power windows not working,i suggest you to go through the help links given below. Click the link to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks
Feb 20, 2012 | 2009 Pontiac G6
Ive lost all my windows media player and all that comes with it, how can i get it back when it will only let me restore it back to the 26/9/2011
Hi jeffqartell,
"Create your "Own" System Restore {Date}.
Go back to "System Restore," and 'choose' to "Go back further than 26/9/2011!"
You can "Create a date by giving it a Restore Point "Date."
e.g. 1/9/2011 etc; with a "Restore Point" reference.
e.g. Disabled, or Deleted "Windows Media Player."
Try this several times if necessary, until it accept, the Restore Point Date!
This will fix the problem, thanks, and best regards!
Sep 30, 2011 | Samsung R530 Notebook
Hi!! How are u? My english not good that much but i will try to explain my problem: when iam open my computerwhich work by windows xp sp3 i got massage the ip operator (3.0208.911.01) is not...
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Microsoft Computers & Internet
I am trying to get rid of the xp home security 2011 virus.
Manual Removal:
1. Press Ctrl+Alt+Del on keyboard to stop process associated to "XP Home Security 2011?. When Windows Task Manager opens, go to Processes Tab and find and end the following process:
(random characters).exe
2. You need to update your installed antivirus application to have the latest database.
3. Thoroughly scan the computer and any detected threats must be removed. If removal is prohibited, it is best to quarantine the infected item. Manually locating and deleting of malicious files should also be performed. Please see files below that are related to XP Home Security 2011 Virus.
4. Registry entries created by XP Home Security 2011 must also be remove from the Windows system. Please refer below for entries associated to the rogue program. [how to edit registry]
5. Exit registry editor.
6. Get rid of XP Home Security 2011 start-up entry by going to Start > Run, type msconfig on the "Open" dialog box. A windows containing System Configuration Utility will be launched. Go to Startup tab and uncheck the following Start-up item(s):
7. Click Apply and restart the computer.
XP Home Security 2011 Removal Tool:
In order to completely remove the threat from a computer, it is best to download and run Malwarebytes Anti-Malware. Sometimes, Trojans will block the downloading and installation of MBAM. If this happens, download it from a clean computer and rename the executable file before executing on the infected computer.
Using Portable SuperAntiSpyware:
To thoroughly clean a computer, it is best to do a separate scan of another security program so that other infected files not detected by anti-virus application can be remove as well. Download and run SuperAntiSpyware Portable Scanner.
Apr 06, 2011 | Computers & Internet
Dear gentlemen/ladies Tried to upgrade to Windows Live Essntials 2011 as well as trying to upgrade Windows Messenger but on my home WIN-XP incl SP3 computer as well as my Viste Home when downloading the...
Windows Live essentials 2011 was writen for Windows 7 users only..
You need to uninstall windows live and reinstall the previous version of the live software.
Jan 24, 2011 | Computers & Internet
Hello, I've got a problem with error code 401 when panda internet security 2009 (license up 3 pc's) is traying load update from internet, my license is active until 01.2011,thenks
The error code 401 is due to a conflict in virtualization system. Here's how to fix this: Click on the Windows logo at the bottom left (Start), write APPDATA in the text box and click Enter. On the window that will open go to the Local > Virtualstore > Program Files. Delete the folder called either Panda Software or Panda Security. Open the anti-virus. Enter your update details again and update your security solution.
Aug 15, 2010 | Panda Internet Security 2009 - 3 User for...
Deleted windows security on spybot
It sounds like a setting in the security center that got changed to me, rather than something deleted. Try this: Go to Start>Control Panel>Security Center and choose the lower Automatic Updates from the Manage my settings at the bottom of the window. Make sure the pop up window has automatic checked on.
If you can't change that setting for some reason, go to windows update, here, and manually update your system. Apply any critical or security updates it recommends, reboot the computer twice, then check the security center and see if you can set automatic updates to automatic. That should stop you from being prompted to download and install updates.
If this procedure doesn't work for some reason, then you may indeed have deleted some important system file, and we'll need to run chkdsk or sfc scannow to repair the corrupted system files. Write back with the results and we can take it from there.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 10, 2009 | Microsoft Windows XP Home Edition
Want to delete ms antispyware 2009
Can you try to delete in "Control panel" "Add and Remove Program" .
Jan 31, 2009 | Microsoft Windows XP Home Edition for PC
E-Machines eMachines Desktop PC Logo
15 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
