Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Kenmore upright freezer
I am going to be moving a Kenmore upright freezer. If I unplug it, do I have to take any special precautions? Will a lot of water be involved? If so, what can I do to minimize the mess it makes?
    Problem Solver:
  • 4 Answers
Why not put on its back? Can you put it on its side?
Posted on Oct 08, 2008
  • 525 Answers
It is best to unplug the unit, open the door fully and let stand 24 hrs. to thoroughly defrost. Empty the drain pan if so equipped.
Wipe out interior with a dry cloth, then locccck or otherwise secure the door so that it cannot open. Place a moving cart on the non-hinge side to transport it, and never lay it on its back.
Posted on Jun 20, 2008
Electronic control on Kenmore (by Frigidaire) upright freezer worked when first plugged in, but though Ive tried both holding down & frantically pressing the UP arrow, seems to be stuck on OFF mode.
I am Taking a guess at this. May or may not work. Have you tried unplugging the unit?, and leaving it unplugged for 5 or 10 minutes? I have noticed with everything these days having electronics involved, severing power often resets everyuthing to a default position. You might try it if you haven't already.
also, there should be in the owners manual an 800 number
to call for assistance from the mfr.thwy usually have a tech you can talk to. good luck!
Jul 01, 2015 | Kenmore Freezers
Excess water drips throughout freezer during defrost cycle
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 01, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Just moved a Kenmore 15 upright freezer. Plugged it in and the motor does not come on.
IT MAY SOUND FUNNY BUT STAND THE FRIDGE ON ITS END FOR THE GASES TOCLEAR.LEAVE UNPLUGGED WHILE ON ITS END FOR ABOUT 2/3DAYS THEN STAND UPRIGHT AND PLUG BACK IN THIS MAY NOW WORK..ROB.
Aug 29, 2010 | Kenmore Freezers
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Mar 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Moving a Kenmore upright freezer
there would be a problem if you lay it down. it should be moved up right or max 45 degrees tilt only. oil in the compressor could go to the evaporator and clog it.
front handles could be remove only from the inside. you have to remove the plastic rack of the door and remove the insulation in order to see the bolt holding the handle.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Kenmore Freezers
Where do you see the water coming from ?
Jul 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
148 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
