Question about Frigidaire Refrigerators
I've had this refridgerator for 15yrs and it's been working fine. But lately the bulb went out, I replaced it w/ a new 40watt appliance bulb and it still stays off most of the time. Could it be a wiring problem??
  • 81 Answers
It might be the door switch ? you do know if your fridge is that old its probably using 4 times as much power as a new model.
Posted on Nov 10, 2010
How do you convert lights and refridgerator over to 120 volts on your 2005 Keystone Outback? Everything else is working fine except these two.
You would need to first determine what the appliances are not working. Then you either have to replace them or run new wiring and use a Voltage converter.
Oct 17, 2016 | RVs
Hampton bay fan 40watt bulbs barely come on
Are you just using pull chains for fan & light?
Oct 20, 2015 | Hampton Bay Dryers
Sub zero lights dont work
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Feb 13, 2012 | Sub-Zero 650 / O Bottom Freezer...
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
The bulb in freezer has blown i have tried 3 different bubs all being 40 watt 120v app, bulb that was there was 40watt 115-125 v is there a difference in bulb or is there another problem
Good morning
Voltage is fine .
Check to make sure bulb is shutting off.Door switch might be stuck.
Or water might be hitting the bulbs causing them to fail.
Aug 02, 2011 | Kenmore Side by Side Refrigerator
I wanted to replace the oven light in my Maytag electric oven but I can't get the glass cover or dome off. Does it turn a particular way or direction?
it turns off but might be stuck or melted on possibly because the heat or the factory overtightened it, it will come off might just need a lil elbow grease but be carefull sometimes people break those tryin to remove. i believe its just a 40watt appliance bulb , hope this helps let me know
Feb 19, 2010 | Maytag Kitchen Ranges
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Sub Zero Model 680 - Light in Fridge and Control Panel out
Sep 01, 2008 | Sub-Zero 680 / F
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
114 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
