Question about B&K Precision B+K Precision Triple Output DC Power Supply (BK1651A) Power Supply
Looking for a BK Precision 1670a schematic - B&K Precision B+K Precision Triple Output DC Power Supply (BK1651A) Power Supply
Http://ppl.ug/UPc7vVfijLs/
Posted on Jul 08, 2015
My 2003 Mercury mountaineer low beams won't come on
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
Pinpoint Test B: The Low Beams Are Inoperative
Normal Operation
The headlamp switch sends power through circuit 13 (RD/BK)/15 (RD/YE) to the daytime running lamps relay, then to BJB fuses 42 (10A) (RH headlamp) and 43 (10A) (LH headlamp) through circuit 13 (RD/BK). After passing through the fuses, voltage is then carried through circuits 161 (DG/OG) (RH headlamp) and 160 (DB/WH) (LH headlamp) to the low beam headlamps. Circuit 1205 (BK) is the ground circuit for the headlamps.
Possible Causes
  • Circuit 13 (RD/BK)/15 (RD/YE) open
  • Circuit 697 (BN) open
  • Circuit 196 (DB/OG) open
  • Circuit 1205 (BK) open
  • Circuit 632 (GY/OG) open
  • Circuit 12 (LG/BK) open
  • Daytime running lamps relay
PINPOINT TEST B: THE LOW BEAMS ARE INOPERATIVE Test Step Result / Action to Take B1 CHECK CIRCUIT 196 (DB/OG) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Headlamp Switch C205a.
  • Place the headlamp switch in the headlamps ON position.
  • Place the multifunction switch in the low beam position.
  • Measure the voltage between the headlamp switch C205a-8, circuit 196 (DB/OG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to B2 .
No
REPAIR the circuit. TEST the system for normal operation. B2 CHECK THE HEADLAMP SWITCH
  • Carry out the headlamp switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Is the headlamp switch ok?
Yes
GO to B3 .
No
INSTALL a new headlamp switch. REFER to Headlamp Switch in this section. TEST system for normal operation. B3 CHECK CIRCUIT 13 (RD/BK)/15 (RD/YE) FOR AN OPEN
  • Disconnect: Multifunction Switch C202c.
  • Measure the resistance between headlamp switch C205a-9, circuit 13 (RD/BK) and the DRL relay:
    • (early build) pin 3, circuit 15 (RD/YE)
    • (late build) pin 5, circuit 15 (RD/YE)
  • Is the resistance less than 5 ohms?
Yes
CARRY OUT the multifunction switch component test. If the switch tests OK, INSTALL a new multifunction switch. REFER to Section 211-00 . TEST the system for normal operation.
No
  • Battery junction box (BJB) fuse(s):
    • 16 (15A)
    • 22 (20A)
    • 42 (10A)
    • 43 (10A)
    • 46 (20A)
  • High beam relay
  • Circuitry
Sep 10, 2015 | Mercury Cars & Trucks
How do I find an an electrical schematic for a Gromes Precision GTE 100 amplifier?
http://www.grommesprecision.com/precisionelectronics/literature/literature.htm
Jul 31, 2014 | Grommes-Precision AX250 1.5 Input Channel...
When looking into setup, dell precision 690 not showing secondary processor
using my noggin i would say bios does not support the processor you are trying to use, and you will have to change the bios.
link below has useful info bios chip compatibility and so on.
http://www.tomshardware.com/forum/261984-28-upgrade-dell-precision
Sep 17, 2012 | Dell Precision Workstation 690 -1KW Dual...
I am looking for a manual for a fordham sg-490 signal generator
These models are all the same.
BK Precision 2005B
Tenma RF Generator model 72-585
Fordham SG-490
http://www.mcmelectronics.com/content/ProductData/Manuals/72-585.pdf
Sep 27, 2011 | Electrical Supplies
I am looking for a kinki waterpump on yanmar diesel engine
Which kind of kinki impeller you need?We have the KINKI BK-0132 and BK-0134
Flexible Rubber Impellers replace KINKI impeller BK 0132 BK0132 Neoprene Flexible Rubber Impellers replace Kinki Impeller BK 0134 Neoprene
I hope which can help you:-)
Best regards from Vera
Flexible Rubber Impellers Mfg Co.,LTD
No.285 Yunshan Rd,National Hi-Tech zone
Ningbo 315040,China
Tel:+86-574-66850926
Fax:+86-574-66850926
Email:sales@flexible-impeller.com
http://www.flexible-impeller.com
Aug 27, 2011 | Computers & Internet
INTERNAL electronic schematic Powertrain Control Module part number 56044513AC for 1998 JEEP Grand Cherokee with a 4.0 engine.
I understand you are looking for the schematic but it's going to be hard to located.
As your are waiting for the schematic,I recommend you to start checking for damage on the electrolytic capacitors inside the Power-train Control Module.
Here are few sample pictures of what your need to look for. These are not the actual pictures of your TCM.
Look for sign of leaks on the base of these capacitors. The leak will be on the circuit board. mustgo_25.jpg
Also look for top of the capacitor. A failing and failed capacitor will be CONVEX outward. mustgo_27.jpg
Replace these caps with the same micro f rating. The voltage rating can be higher then the exiting cap.
I hope some expert can come though with the schematic but checking all capacitors for damage is a good start.
Please keep me up to date on the repair and upgrade via email.
Jan 24, 2011 | GPS
Looking for Dell Precision 470 Manual
Dell Precision 470 Manual can be downloaded from the following link: -
http://www.andovercg.com/datasheets/dell-precision-470-workstation.pdf
Hope you get all the information you need!
CreativeTECH
Nov 19, 2010 | Computers & Internet
I NEED SCHEMATIC DIAGRAM FOR PRECISION COLOUR TV MODEL PTF29R99S
cannot get no parts for this tv ptf29r99s precision
Mar 03, 2009 | Televison & Video
Police scanner
http://www.repeater-builder.com/bendix-king/b-k-index.html
Oct 08, 2007 | Bendix King LPH, LPA, LPX, EPH Compatible...
B&K Precision B+K Precision Triple Output DC Power Supply (BK1651A) Power Supply Logo
639 people viewed this question
Top B&K Precision Computers & Internet Experts
David Payne
David Payne
Are you a B&K Precision Computer and Internet Expert? Answer questions, earn points and help others
