Question about Centrios EDW8020 DVD Recorder
Have a centrios dvd recorder EDW8020 and the remote does not work. have changed batteries is there a way to reset this the buttons on dvd recorder works so it the remote that is having trouble
  • mbamvakais Nov 14, 2010
    do not have a ir detector
  • mbamvakais Dec 08, 2010
    tried all these and no help
    Genius:
  • 1,622 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassemble so re-assembly will be easier.
step 4Pull everything apart
Did you take a picture of the key pad layout? Sometimes keypad is just one rubber membrane. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develop dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lens or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a small bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dish wash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before, Once you have completed test with your camera you can use the remote.
Hope this will help in solving the problem.....
Posted on Dec 02, 2010
  • Centrios Master
  • 17,129 Answers
FIrst of all it is important to confirm that the infra red(IR) emission from the remote control works. Use a IR detector connected to the multimeter in the resistance check range( ohms) with the right polarity . Now press the remote pointed to the IR detector and if there is no response you will need to open and check the remote control Unit.
If so click this link for help: remote control repairs.
If there is response and detection then the DVD must be checked for IR detection and processing in the control panel.
Posted on Nov 10, 2010
The remote does not work. What is the code for a universal remote
all kinds of universal remotes,it would take all night to list them all
Apr 30, 2015 | Centrios EDW8020 DVD Recorder
My centrios edw8020 dvr records o.k. but won't play dvd on any other dvd systems
If the disc is not "finalized" it will not play on other DVD players. The steps to finalize the disc are part of the DISC Utilities Menu. under "DISC OPERATIONS". Choose "FInalize DISC". Instructions refer to finalizing DVD=R disc, so you may want to try this type of disc first and see if it works. Says It can be used as DVD-Video disc but results are not guaranteed. You can not edit disc after finalizing, only playback.
Jan 28, 2014 | Centrios EDW8020 DVD Recorder
CENTRIOS DVD recorder switched to black and white output
Hi
As the black and white pic got a snall cross dot patten all over it. If this so the input on your tv that connects to the dvd player as been set to s-video you can change this with remote on tv . regards windyhouse
Apr 03, 2010 | Centrios EDW8020 DVD Recorder
Can't read disc
my dvd player says no disk its not even spinning when its in help please
Sep 29, 2009 | Centrios EDW8020 DVD Recorder
How to record from DVR on Centrios EDW8020 Digital recorder
am new I dont have the manual I need to know how to record I bought the dvr+r disc but its not doing any thing
Mar 12, 2009 | Centrios EDW8020 DVD Recorder
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Edw 8020 remote code
I lost my remote somewhere , so I went out and brought another remote But I dont have the codes to make it work on my centrios DVD recorder can your help me THANK - YOU
Nov 27, 2007 | Centrios EDW8020 DVD Recorder
Centrios dvdrw
If you mean the TV picture rolls- this is a TV adustment or cable replacement requirement Contact the player and TV makers websites Tech Support for this.
May 17, 2007 | Centrios EDW8020 DVD Recorder
Lost Remote Control
Hi
Solution is through The Source or Circuit City. The remote is roughly $12 and takes roughly 10 days to arrive at the store
Mar 01, 2007 | Centrios EDW8020 DVD Recorder
Centrios EDW8020 DVD Recorder Logo
140 people viewed this question
Top Centrios Televison & Video Experts
Henry  Thomas
Henry Thomas
timtation123
Andrew Taylor
Andrew Taylor
Are you a Centrios Televison and Video Expert? Answer questions, earn points and help others
