Question about Brother IntelliFAX 4100 Laser Fax
The fax machine does not pick up paper from the tray
    Guru:
  • 452 Answers
When the paper pick up roller is dirty, ( with the dust) the paper can not be loaded properly, to avoid this problem clean the pick up roller softly with alcohol, use a brush you msut touch the entire surface of the roller, do not forget the separation pad clean it,
Posted on Nov 09, 2010
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Constant paper jam in trays on ir3035
try cleaning the under the roller that picks the paper with nail polish remover and its a go!
Apr 09, 2014 | Office Equipment & Supplies
We have a Brother Intellifax 2820 fax machine, and the problem from the pick up tray after two copies it gives an error "No Paper Feed" can you tell me what is the problem. I cleant the pick up...
Tray this:
open the left cover, check the pick-up solenoid by hand, if it remain as bonded in the part under, you have to remove from the part under the little rubber band with a screwdriver. Then recheck the solenoid if it works good.
Sep 09, 2011 | Brother IntelliFax-2820 Laser Fax
Paper wont feed from the tray gets jammed every time
Take note:
Usually in the tray paper jams are caused by the pick-up rollers being dirty so clean them using a well wrung wet clothe.
Also the clutch and soleinoid problem. Also take not of the transport system for the paper if there is anything not in its right position any thing loose they must have somewhere you shold afix them.
Jul 18, 2011 | Brother IntelliFax-2820 Laser Fax
Paper Jam unable to find
Open the back cover door, clean the roller.
May 17, 2010 | Canon FAX-L360 Plain Paper Laser
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
FX-FL511 PLAIN PAPER FAX
Fax is not picking the paper from tray.just clean paper pick up ruler.or replace it.MIAN AKHLAQ
Jan 01, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Error 011 Panafax 585
The extension at the back of the tray has broken off, so the machine doesn't recognize that the tray has been put back in. Solve this by taking a piece of cardboard (business card works good), fold it up and insert it into the sensor at the far left where the extension would have gone when the tray is inserted. This will trick the machine into thinking that the paper tray has been inserted.
Jul 24, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
341 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
