Question about HP Photosmart C5580 All-In-One InkJet Printer
When I try to make a copy I just get a completely grey page with lines -- no picture when I scan either.
  • HP Master
  • 7,733 Answers
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
I am trying to photocopy some pages of a document in black and white, but the copies come out as colored. what can I do in order to copy only black and white document?
A copy is a copy. you get what it sees.
I think you may be successful in scanning the picture to your hard drive, then print it in grey scale.
Feb 23, 2011 | Office Equipment & Supplies
Thick black and grey line when scanning or copying a document.
Burn the thing it's junk. Go buy a commercial machine if you want something that works.
Apr 15, 2017 | Epson Stylus Multifunction Inkjet Printer/...
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Color page in Batch to file
If you select color mode and scan grey and color pages, the output will be Grey for Grey abd color for color. If you had chosen to scan in grey mode, color will appear in Grey only.
There is an option to scan in both color and B&W simultaneously under multistream option.
S. Mohan, India
Jan 27, 2009 | Canon DR-9080C Path-Through Scanner
Lines on copies and scanned images
I would type it all out but hp has a great little document - complete with pictures!! The issue is that there is something on the small strip of glass that is used for the feeder and needs to be cleaned.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Scan problem
try copying a page and see if that works
that will prove the unit is not faulty
if that works unplug the printer uninstall the printer software restart the computer reinstall the printer software and plug the printer in when asked.
if copy doesnt work the unit is most likely faulty
Oct 29, 2008 | Epson Printer
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
HP Photosmart C5580 All-In-One InkJet Printer Logo
74 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
