Question about Singer CG500 Mechanical Sewing Machine
When i turn the handwheel towards me to lower the needle to pick up the bobbin thread, it lowers but doesn't pick up the bobbin thread...
I had this same problem and I was told to make sure the bobbin is in with the thread coming out counter-clockwise and it solved the problem for me on all three of my machines. A lot of times the needle will pick it up but you have to do a full rotation on the handwheel. I hope that helps
Posted on Nov 09, 2010
My featherweight singer will not pick up thread in bobbin
The singer 221 needs to be threaded with the flat side of the needle on the left side. The thread passes through the eye of the needle from right to left. If this does not solve your problem it may be out of time. You can remove the needle plate and watch the hook it should pass above the eye of the needle as you turn the handwheel towards you. First you need to make sure the needle is at the correct height before adjusting the timing on the lower shaft. You may want to take this in for service if your timing is off.
May 14, 2014 | Sewing Machines
Threading a needle
1. Turn handwheel toward you 2. Raise presser foot up 3. Pull thread from spool and pull taut under each tension disk. It's important to "feel" the "click" if you are new to threading machine 4.Make sure after all tension disks threaded that you put thread behind the slot in back of your needle. It's a little groove to hold thread securely. 5. Pull thread toward you 6. Thread needle eye front to back 7. Pick up thread under gently pull taut in front of you 8. Lower presser foot and turn handwheel toward you. A loop will form under the needle where needle thread has picked up the bobbin thread. Carefully take both threads that have made a single loop and pull toward you 9. Put threads under presser foot just lift put threads under and pull 5 -6 inches thread BACK and UNDER that presser foot Done! Hope this helps, my friend! Jimmy
Mar 30, 2012 | Sewing Machines
The top thread won't catch the bobbin thread to pull it through. It almost seems like it doesn't go around to pick it up. Or is the bobbin thread supposed to pop up more for pick up? This is my Mom's...
check the needle to see if it's damaged
have a thread tail for the top thread & bobbin thread of 3-4 inches
try this & see if it helps you
make sure there's a 3-4 inch bobbin thread then, hold the top thread tail (3-4 inches) with your fingers away from the needle & then use the handwheel on the right side of the machine & lower the needle down into the bobbin area & see if it pick up the bobbin thread that way
make sure there's no lint or loose threads in bobbin area
Sep 24, 2010 | Sewing Machines
I have a singer 2263 and i have it set up. but my problem is that i cant seem to make it pick up the bobbin thread with the needle. i have been following instructions but the thread binds up around the...
Have you pulled up on your top thread as it loops the bobbin thread? You are supposed to hold on to your top thread with your left hand and then lower your needle with the handwheel, you have to turn the wheel towards you not away from you or else you can mess up the timing. You will see it catch the thread and you will know to pull it up.
Sep 21, 2010 | Singer Sewing Machines
Needle does not pick up thread from bobbin
Is your needle inserted with the flat side facing the rear of your machine? Are you holding your top thread as you rotate your handwheel toward you to lower the needle? Is your bobbin threaded right, check your manual. It is usually something very simple when this happens.
Sep 09, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Instruction on how to thread shark euro sewing machine
If you can email a picture I can help you drivewithken@blueyonder.co.uk
Mar 06, 2010 | Euro-Pro 7500XH Mechanical Sewing Machine
I can't get the needle to pick up the thread from bobbin why not?
Take the thread out of the machine.
Make sure that a new needle is inserted properly; this is critical.
Place the presser foot up and turn the handwheel towards you until the take-up lever is at its highest position.
Thread the machine.
Always turn the handwheel towards you. If you look at it from the right side it should turn counter-clockwise.
If it still doesn't pick up the bobbin, reply.
Jul 24, 2009 | Juki Sewing Machines
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Singer CG500 Mechanical Sewing Machine Logo
160 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
