Question about Acer TravelMate® C314XMi (G16012) Tablet PC
The laptop would not boot up. It was hooked up to an external screen and then a few hours later, there was nothing on the screen. It wont boot up into a POST screen
    Brigadier General:
  • 8,909 Answers
Dead Laptop?
Try firstly removing the laptop's battery as it may be at a critical voltage and the system will not start because of it. Plug in your ac adaptor and monitor what happens. Does the power light illuminate? If it does it should then boot up, if it doesn't, try a known good ac adaptor before going any further.
If the adaptor is fine then you have a mother board fault and should contact a dealer/repairer for further advice.
Hope this helps.
Posted on Nov 09, 2010
I charged my tablet and turned it off for a few hours and now it wont cut on
Press and hold power button for a few seconds.. To run safe mode.
This is a common problem caused by power fluctuations.
Nov 12, 2015 | Tablets & eReaders
NOTHING BUT A BATTERY AND RCA TABLET COMES ON WITH CHARGER BUT SHOWS NOTHING BUT A BATTERY ON SCREEN RCA 7 INCH TABLET
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
Feb 26, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
How do i get my asus tablett out of frozen
Assuming the restart option isn't available after pressing and holding the start button for a few seconds; you can let the battery drain ... but it may take a few hours. (Adapter must be unplugged). Then connect the adapter and restart. Another way is to remove the battery.
After the tab restarts check if system updates are taken care of. If the problem happens because of a particular app consider to uninstall that app.
Feb 17, 2015 | ASUS MeMO Pad HD 7
How do I fix a DigiLand tablet?
The reset process can take some time, but usually no longer then an hour MAX.
Sounds like this device may be defective with all the issues you have been having. Contact the number and ask for a replacement or refund.
Jan 20, 2015 | Tablets & eReaders
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Laptop Screen Dull
Look a the screen real close, if you see a faint dark version of the image, this could be a backlight issue, otherwise a screen cable or a logic board issue. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. Check on how to take the screen apart and make sure inverter is still connected properly. If so, you have a backlight issue. I work for Computer Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Nov 18, 2008 | IBM ThinkPad X41 Tablet PC
Toshiba Portege 500 Laptop
need a toshiba mother board for m40x250
Aug 04, 2008 | Toshiba Portege M400-S5032X Tablet PC
Random Fatal Stop Error
The driver irql_not_less_or_equal error can have multiple causes, but most of the time it is a hardware/driver issue.
Check if there are any new drivers available for you computer's hardware devices and update them if so.
Running a memory test also does not harm, could be faulty RAM.
Apr 15, 2008 | Toshiba Portege M205-S810 Tablet PC
Acer TravelMate® C314XMi (G16012) Tablet PC Logo
189 people viewed this question
Top Acer Tablets & eReaders Experts
Nicola Conroy
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
