Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Solve using continuous compounding- A=Pe^(rt) P= $17,425 r= 4.25% A= $25,000 t= ?
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
How do you find out how long it would take to triple an amount at 6% interest, compounded continuously?
Solve the formula e^(rt) = 3 , where r=0.06 per time period
(see http://en.wikipedia.org/wiki/Compound_interest#Continuous_compounding for details)
Taking the logarithm of both sides and rearranging gives: t = ln(3)/0.06 = 18.31 time periods. The logarithm function is a shifted function on the 2 button on the 10bii calculator.
May 09, 2011 | HP 10bII Calculator
How do I solve a continuously compounding equation on my TI-30XA calculator? An example: 10000(1+.06/12)^10*12
That's 10,000 for 10 years at 6% interest compounded month.
Press
1 0 0 0 0 * ( 1 + . 0 6 / 1 2 ) y^x ( 1 0 * 1 2 ) =
Apr 07, 2011 | Texas Instruments Office Equipment &...
Intercom system on my motorcycle shorts out the circuit
use a continueity meter which will tell if shorting to earth
Apr 08, 2010 | 2004 BMW R 1150 RT (ABS)
I just downloaded and installed PE 8. Sometimes when I start the program I get a message that says Multi Support Module doesnt work with this version of Photoshop. What is it, should I be concerned. My...
For your PE problem . Just update your system online .
and problem will be solved.
If that didn't solve the problem , then uninstall the PE and reboot your system and install it again and reboot your system once again .
good luck
Feb 11, 2010 | Computers & Internet
Hi my name mohit manchanda. actually i wanna instal win xp in my [pen drive but after copying files 100% than sytem show fetal error
All that's needed is a bootable USB Flash drive with at least 256 MB of storage capacity and a Windows Setup CD. Using the program Bart PE Builder (Freeware), you can install Windows XP on the flash drive, along with other software as needed (and as available space permits).
Here is the link of Bart PE Builder
http://69.90.47.6/mybootdisks.com/mybootdisks_com/nu2/pebuilder3110a.exe
Here is the procedure
This will help you create your very first BartPE CD. It assumes that you are using Windows XP.
Make sure that your system has about 500MB of free disk space!
Download the latest PE Builder version (self-installing package) and install it.
Start PE Builder (pebuilder.exe). When you start PE Builder for the first time it will ask if you agree with the license agreement.
Now PE Builder will ask to search for windows installation files. If you don't have your windows XP setup/installation files on your system you must insert the original Microsoft Windows XP installation/setup CD at this point.
The files you have at c:\windows are not installation files. They are your already installed files!
Click "yes" to start searching. PE Builder will now search all fixed- and CD-Rom drives for Windows installation files. This will take some time. When more than one valid location is found, a dialog will appear where you can select which location you want to use.
At the main PE Builder dialog, select the "Burn to CD/DVD" option. When you are using an erasable medium, make sure that the "AutoErase RW" option is enabled. The "burn using" option should be set to "StarBurn". Select your CD writer device from the Device list.
Hit the "build" button. PE Builder will now ask you to create a BartPE directory, answer with "yes".
The license for your Microsoft Windows XP product is shown. Read it and agree to it to continue.
PE Builder will now start building BartPE. This will take a few minutes.
You will see a lot of files getting copied and/or decompressed, the ISO image build and the data recorded to your CD/DVD writer.
If the data verify was correct and there where no errors reported you can boot the CD/DVD!
After that set your PC BIOS to boot from USB,then restart.
That's it.
Dec 11, 2009 | Dell Dimension 4600 PC Desktop
Only humming noise from speakers
The humming is probably caused by failing filter capacitors, these are usually quite large, also look for cold solder joints around parts the heat and cool continuously. Please post an update to further troubleshooting, if this doesn't solve the trouble.
Jun 19, 2009 | RCA RT2500 System
TI 83
Yes you can use it, here is the formula: Y= V(t+ (i/c))^(tc) V=amount put in, t=time, i=intrest rate, c= amount of times it is compounded.
(I know this because I have a TI-83 calculator)
Mar 27, 2009 | Texas Instruments TI-83+ Graphing...
New Rt rear tire losing air slowly...
Hi there!
Yes they should be able to sort it out for you.
Chances are it is not sealing on your rim,
Take it back to them, they will deflate it, paint a compound on the rim areas, then re-inflate it.
If you remove the tyre yourself, and immerse it in water up over the rim, you can mark the area if it bubbles.
You can self-fix by using impact adhesive on the rim - when tyre is fully deflated on this area.
Tyre rubber compounds are soft in this area and should conform to seal within a month or so, but sometimes don't make it.
The other reason is that rust or a crack may be evident.
If this provides a solution, Please spare a moment to rate as Fixya! Thanks.
Jun 19, 2008 | 2006 Nissan Maxima
PE Problem
I don't know of PE as a error for the dishwasher, however stranger things have happened.
Lg has had problems with older units prior to mar 07. They have had wires breaking in the door. If you turn off the power and remove the panel. Look for broken wires and or wires stuck in the insulation. Check for continuity as sometimes it can be an internal break. Fix this and you should be good. Oh put some insulation between before closing it up .
Sgt 48
Apr 14, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
371 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
