Question about Dishwashers
Maytag HDB8600AWW Dishwasher had been making noise (thought might be water valve, like previous DW), eventually stopped draining water, water now in bottom, I've let sit for couple weeks, looked inside, water was gone, I tried running again, it filled with water, but heard humming control panel noises for first time, then shuts itself off. Also, my handle needs replaced. Please let me know as soon as possible. Thanks in advance. David Weaver
  • 4,323 Answers
Hi David
The hum and all the noise that you have mentioned in your post states that the issue is with the pump and motor assembly. Please check the drain hose and try to clean the drain pump filter for any clogs, obstructions. After this if the problem still remains then replacing the part# that is bad is recommended repair. Hope this helps...you can post back if you need further assistance.
Daniel
Posted on Nov 09, 2010
9-14-14 How do I increase dishwasher pump drain pressure?
Wow, you've really tried hard to fix this problem (and describe what you've tried to do to fix it). But for me to be able to fix it, I need to know the model number, and approximately how old the dishwasher is. Does this model use a separate drain motor, or does it have just one motor and a diverter powered by a solenoid to drain the water?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 14, 2014 | GE Dishwashers
DW doesn't pump out. Pump doesn't come on. There
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 09, 2009 | Frigidaire Dishwashers
Maytag dishwasher doesn't completely drain!
First check to see if anything has gotten into the sump drain inside the bottom of the dishwasher tub. Sometimes a piece of plastic wrap, or other small item can become lodged there, causing the DW to drain slowly.
If nothing there, check the air-gap device at the sink, as these can become clogged over time and that would also prevent proper draining. The air-gap is the round (usually silver chrome colored) cap mounted on the corner of the sink). Pull off the cap, it comes straight up with a little twist and polling motion. Clean out the screen filter and also look down the hose to see if there are any obstructions in the drain hose.
If that is OK, check the drain hose from the air-gap down to the connection at the sink drain, or if you have a disposal, where it is connected to the disposal. Sometimes small bits of stuff can get stuck in the hose at these various points and any build up over time, will make proper draining difficult.
You can also flush the drain lines with hot water to make sure the lines are clear. If none of this works, you could have something in the DW sump pump and that will require removing the DW from under the counter and checking the pump area for obstructions. Sometimes you can easily remove the flexible pump body and get at the drain valves. Just be sure to disconnect the power and turn off the water supply before removing the DW to attempt any repairs.
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher makes a loud noise until I turn on the water in sink
You have too much water pressure it sounds like for the fill valve to operate properly. I am assuming it is chattering? How much water pressure do you have? If its too high an inexpensive regulator can be purchased at most plumbing supply stores to install in the DW supply line.
Jul 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Apr 14, 2009 | Frigidaire 24 in. PLD2850 Built-in...
E1 Error code - no leaks - new pump - new pc board in Dec. 09
The most common reason for an E1 error on an LD dishwasher (that does not have a leak, including directly under the dishwasher) is the drain hose between the dishwasher and the drain does not have a rise in it between the DW and the drain. Either install a proper AirGar valve or attach the hose to the bottom of the counter top so that it raises 30" between the DW and the drain. When that raise does not exist, the laws of physics tell you that you WILL have a siphoning effect from the DW into the drain, causing the LG to report error code "E1", which is true because of the water leaving the DW during all the wash and drain cycles.
Good Luck!
Apr 03, 2009 | Dishwashers
Problem with water cycling
You say the water valve is open, are you referring to the supply water valve, or the water valve inside the dishwasher?
If the supply valve is open, then chances are that the electric water valve inside the dishwasher is bad, or the dishwasher control is bad.
Usually, the water line connects right at the water valve, underneath the dishwasher.
Reply with the make and model number of the DW and I can give further instruction if you or someone you know is good with a multimeter and reading schematics or wiring diagrams.
Jan 15, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB7160AWW fills water for a minute then stops
hi there,
please provide the model # and any error messages on the display please.
thanks,
c
Jul 24, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Water continues to run, even when unplugged....
Hi, had the same problem. Water would not stop entering the dishwasher until the water valve for dishwasher was completely shut off. (Even when circuit breaker for dishwasher was turned off, the water still came into the dishwasher). Well after research, it is the water inlet valve. Replaced it yesterday and it is working as good as new. Look up this part online if you aren't sure what it looks like. Good luck,
Jan 08, 2008 | GE 24 in. Profile PDW7880G Built-in...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
