Question about Kirby G4 Bagged Upright Vacuum
SWEEPER SMELLS LIKE SOMETHING BURNING, BUT WORKS WELL. DOES IT NEED A TUNE-UP AND CAN I DO THIS MYSELF?
  • 144 Answers
I would check if the drive belt has a scorch mark on it, you may have caught something that temporarilly jammed the belt causing it to slip hence burning smell. I wouldn't suspect motor or anything serious as it works. So if need be change the belt. May be worth checking if the roller is turning it may be jammed.
pete
Posted on Nov 09, 2010
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
When I was vacuuming this morning it smelled like burnt oil or something. The powerhead was not working when I checked. Can I get a new powerhead or is there another solution?
It sure sounds like your belt is burned off. You need to have it looked at before replacing the unit that's for sure. If the sweeper assy. under the vac is not turning than the belt is broken. Go to GE 106766 belt on the web and you sould be able to get it delivered to your door. Good Luck.
Dec 07, 2010 | GE 106766 Bagged Canister Vacuum
What is causing a slight burning rubber smell when running the vacuum?
If this is a sweeper model with a rotating brush, remove the brush assembly. Clean and oil (3-1oil or similar) the bearings on the ends of the brush. They are usually full of string, hair, and thread which binds the brush. Check the belt for burn spots or other damage. Hope this helps!
Oct 04, 2010 | Vacuums
Progressive drive bagless and beltless sweeper (purple) that has a burning smell when running, what could it be?
most likely the brushroll motor which is located inside the brushroll. This machine is one of the worst designs produced by kenmore, usually the brushroll motor only lasts 2 to 3 yrs.
Jan 06, 2010 | Vacuums
WHEN I TURN ON UNIT IT SMELLS LIKE WHEN THE RUBBER BELT STOPS TURNING ON A SWEEPER. HOW DO GET TO THE MOTOR AREA?
Mosture has gotten into the motor. Take the bottom tank off and let the unit run for 30 seconds. It will dry out the compartment
May 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
130 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
