Question about Garden
16 hp briggs vangard blows clouds of smoke under pressure
  • 7,482 Answers
Normally the smoke is cause by one or two problems.
1...too much oil in the crankcase, lower oil to correct level and smoke will stop.
2. broken rings,bad valves inside of the engine, major overhaul or replace the engine with a new one is the only repair for this problem.
Please rate me
Posted on Dec 26, 2010
WHY DOES WHITE SMOKE COMES OUT OF THE SIDE
If it's coming from around carburetor area than you most likely have a blown head gasket. It's building up to much pressure in block and its blowing out your vent tube.
Jul 28, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Vangard v twin valve adjustment
I can walk you through it but too long for here so...Go into Utube and ask the very same question..STARTING WITH UTUBE THEN YOUR QUESTION..some very good sites there..good luck
Aug 21, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Vangard model 305447 type 0068 e1 code 05102611 will not say runining on rough ground
It can be several problems. It might be that the carburator is loose and when it shakes over rough ground it is sucking air and stalling. If it is something else you might try rubber mounts under the engine to take the vibrations out of it. Also check for loose wires.... there may be a wire grounding out when you travel over rough ground. look for loose connections or frayed wires that might touch metal and cause a ground
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Trying to find starter for 12.5 vangard v twin motor. my model number is 9108304 on starter but can't find anything the same.
anytime you deal with small engine parts you MUST be armed with the engine model number, code and type. on late briggs these are on one of the valve covers.
Feb 08, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
My Briggs Vangard 18hp twin V has problems starting. I replaced the starter solinoid but it is still a no go. I can jump the solinoid and get the starter to spin but no fire to the plugs, Any ideas?
This is most likely being caused by one of the safety switches cutting off current flow to the solenoid. turn the key on and jump the solenoid and see if you get spark to the plugs. If so you have a safety switch issue...one is under the seat, one is on the clutch pedal, one is on the reverse position and one is on the blade engagement lever. hope this helps you
Dec 01, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Oil in aircleaner and smokes
You need too drain your oil and make sure you put the proper amount back in too much and it will shoot oil and smoke...
May 09, 2009 | Briggs and Stratton 073001 2" Portable Gas...
Need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Apr 18, 2009 | Briggs & Stratton Garden
Carburator problem,18 H.P Vangard V-Twin(350777-1113-E1)
it sounds like the needle valve is stuck open. This is connected to the float, and when the bowl gets low the float pulls this needle out of its seat and allows fuel to run in. Sometimes tapping on the bowl can resolve this. The needle is usually made of brass and can become corroded from water or from sitting or wintering over. if you take the bowl off you could also clean this up if tapping a little does not resolve the issue.
Apr 13, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
