Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Lost my owners manual, where is it located
After my tv sat for 2 years i finally got replacement bulb... where is it located on tv
  • 4 Answers
Http://www.docs.sony.com/release/XL2100U.pdf
Posted on Jul 17, 2008
It is behind the power button, there will be one screw on each side of your t.v. " by the hand slots to lift the t.v."you should be able to unscrew them with your fingers. they do not come all of the way out. then pull the face plate off. the bulb is on the left center.
Posted on Jun 17, 2008
How to replace bulb
Things you will need: 1. Philips screwdriver. 2. Pair of pliers. 3. A new bulb. Note: The new bulb should be handled with care. It doesn't hurt to do a final wipe with a clean, non-abrasive, lent free cloth before the final installation of the bulb. Steps to replace bulb: 1. Turn off the main power to your TV. 2. Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on releases. 3. Remove the screw securing the lamp cover with a Phillips head screw driver and remove the lamp cover. sdulin.png 4. Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.sdulin_0.png 5. Next remove the metal cage by pulling outwards and away from the plastic enclosure, the metal cage should come loose. In the picture below you can see a groove where you can place your thumb inside and pull .sdulin.jpg 6. Now unscrew the scew holding the connection plug in place as well as the two screws holding the bulb in place. sdulin_1.jpg sdulin_0.jpg 7. Now take out the bulb from the enclosure. 8. Next swap out the power plug from the old bulb onto the new bulb. Our pliers come into use here to remove the nut from the center of the lamp. sdulin_2.jpg sdulin_3.jpg
Note: Be careful when screwing in the side connector on to your new bulb. It's best to hand torque here as it is very sensitive and might break with too much torque. sdulin_4.jpg
9. Now assemble in reverse order and you're finished!
Mar 06, 2011 | Hitachi 42V515 rear projection TV lamp...
How do I access the lamp on a Vega KF-60WE610?
This page shows Sony lamp location and bulb replacement.
Sony DIY Bulb Guide.
The XL2100 Lamp assembly is located behind the grill, under the front screen. Thumbscrews on left and right loosen and the panel pulls off.
Open Lamp access door by loosening the thumbscrew on the front. The lamp is behind the door and attached by two mounting screws. The mounting screws require an "Allen" or Hex key.
Never attempt to access the bulb or open the door when the bulb is hot. Allow 30 minutes to cool.
Look for specific LED indicator codes on the front of the TV. An explanation of the most likely fault is in your Sony user's manual. Links to free Sony user manuals are also on the link above. Lots of instructions regarding safety, mercury disposal, removing the lamp.
Do not buy a bulb and waste your money if any Sony TV Optical Block or Optical Engine Faults are or were visible before bulb failure.
easyab
Jan 27, 2011 | Sony XL-2100U Projector Lamp for...
I have replaced the lamp 2 times ....think it needs a 3rd tv is almost 6yrs old .. but now it will not even turn on ! will a new bulb turn tv back on ?
did you check the power supply board and also did you check the ballast our the digital board those could be the problems that you 6 year tv could have
Dec 15, 2009 | Samsung - Projection TV replacement lamp...
Sony, SXRD Projection TVKDS-55A2000 Was working fine, then picture vanished. We have red blinking light on front, indicating lamp. I presume that lamp need to be replaced, but TV has only been operating...
Same thing happened on mine, you need to replace the bulb, on our TV I have 2 kids so the TV was always on but lasted 2 and a half years which impressed the warranty people. From what I have heard the average life is about 2 years. I have the same SXRD TV.
Aug 10, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
I have only had my sony tv for 2 half years and it needs a bloody lamp already whats going on with sony it was one of the leading companys now its gone right down hill i should not have to pay out already...
Hi I am Vortash sorry to say lamps are notoriously thee major cause for 90% of projection tv failiures , and unfortunately you can never guess how long they will last .
Yes sure they say they will run for 3000 hours but not always as factors like posistion and airflow to the set will alter the opperating characteristics of a lamp the hotter they get the shorter they last , thats why there is no guarantee with a bulb once it is out of the packet . The next bulb you buy may last 3 years or it may last 2 or even 1 , so if you want your b8ulbs to last check that your set has a good airflow around it and that the fans are working correctly , that will pro;ong the life of your bulb .. regards Vortash
Jun 22, 2009 | Sony (XL-2400) Projector Lamp for...
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Hitachi replacement bul
    Let me know exact model of your Hitachi TV to check bulb availability in parts stores.
    Bulb replacement is easy process and mostly it is written on owner's manual of TV.
    Please use "add a comment" button to intimate model number of TV.
    Thank you.
    Apr 06, 2009 | Hitachi REPLACEMENT LAMP, Projector Lamp...
    Bad Blub?
    probably a capacitor in the tv is going bad. contact your sony repairman
    Jun 05, 2006 | Sony XL-2100U Projector Lamp for...
    Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
    Top Sony Office Equipment & Supplies Experts
    easy alberta
    easy alberta
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
