Question about D-Link DIR-625 (790069292637) Wireless Router
D-Link Router and ASUS p5E3
I recently purchased the DIR-625 (wireless N draft) along with a D-link PCI adapter for my wife's computer. That connection works fine. My soin is using a "g" PCI card (Belkin) and his connection is fine. My computer is a recent build with the ASUS P5E3 MB. This motherbaord has an onborad Ralink (I really think it's Azureware) wirelss N draft chip. It will not work with the Router. Although it indicates a connection, the download speeds are abysmall and eventuall just locks up altoghether. I also installed a Belkin PCI (g) adapter which works fine.
  • 5 Answers
SOURCE: QOS on D-link dir-625
buy a linksys wrg series router and smash that dlink peice of junk into tiny little pieces, put them into a bag and mail to dlink, with a letter describing your opinion of their products.
Posted on Jan 31, 2008
oldnovii
  • 667 Answers
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 31, 2008
kakee
  • 1268 Answers
SOURCE: D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
Posted on Feb 13, 2009
SOURCE: D-Link Wireless Router DIR-625 unable to connect with D-Link DWA-130 adapter
Called the Support Line. They suggested changing the DNS Server gateway to 4.2.2.2 and the alternate to 4.2.2.3. Leave Obtain IP Address automatically. Make these changes in the properties of the NIC card. Also uncheck IPv6.
Posted on Mar 10, 2009
  • 9 Answers
SOURCE: D-Link DIR-625 - wireless problem
there may be several issues based upon your description based upon the pcs that attempt to access the router wirelessly -
what are the OS? Vista? XP?
Do the PCs have firewalls installed? How are they configured?
Are your PCs configured with different subnets or static IP addresses from the router? To explain - if your router has an ip address of 192.168.0.1; and your pc does not have a dynamic ip address (set by the router), but rather, is set for 192.168.1.2, you won't be able to connect - you'll need to modify the ip address on the pc.
On the router, how is the wireless setup? do you require MAC addressing? what is the security? WEP? WPA?
Posted on Jun 28, 2009
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
Very slow loading videos
Set you router to WPA security:
For this DIR-625 router if the encryption is set to WEP it could only give up to 54mbps wireless connection. If it is set to WPA it can give up more than 100mbps wireless connection, but it depends if the wireless adapter in the computer is also a Draft N adapter. Its a backward compatibility.
Nov 27, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have D-link 625 Wireless router but i try to connect on my desk top computer by Belkin G wireless USB network Adapter 5012. If i put password on WSK-Personal ( on wifi password setting) is not going...
Check your settings on your wireless setup and make sure the adapter on your computer is set to Security Type: Shared. That is the most over-looked stumbling block.
Nov 15, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 can not broadcast wireless continously
LOOK AT BACK OF LINK BOX FOR A SMALL HOLE WHEN FOUND TURN POWER OFF ON BOX PUSH TIP OF PEN INTO HOLE THEN TURN POWER BACK ON THIS WILL RESET MEMORY
Jul 19, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-link dir 615
is unit in a surge protector? Any recent power surges? if you plug it in to a "good outlet" and nothing lights up at all (after a reset), either the ac adapter for the router is dead or the system board in the router is dead.
Mar 21, 2009 | D-Link DIR-625 (790069292637) Wireless...
DIR-625 Blocking DWL-G510 connection
1) First you need to check if the router is blocking mac address. Login to the DIR-625 by typing 192.168.0.1 on the address bar of IE.
Use admin for username and leave password blank or type in your password.
Go to Advance Tap, on the left click on Network Filter. Select Turn Off Mac filtering, click on save settings. wait for your to reboot. If that doesn work try option tow below.
2) What you need to do is Upgrade to the latest firmware on your router (Resolves 99% of all problems). Make sure you download the right firmware for there are two version of the DIR-625 ( Rev. A & Rev. C).
You'll also need to make sure you have the latest driver for the adapter since you have a newer computer.
Sep 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
Sometimes the security settings will only let certain MAC addresses connect to the network as well as the password protection. Make certain that yours isn't filtering out MAC addresses.
Aug 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
Jeff
May 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
Purchased a d-link dir-625 so my laptop could be wireless
A lot of laptops have a hardware or software switch to enable/disable the wireless radio. I'd look for that first. I can help you find it better if you provide your laptop model.
Feb 18, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
101 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
