Question about D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k)
Laptop networked to desktop with DSL
Is there a way that I can access the internet from my laptop (came with wireless) to my desktop (with DI-514/DWL-520 wireless router and card) with DSL? When I try IE from the laptop, it gives me a connection problem. If I run diagnostics on it it gives me a choice of wireless or ethernet connection. Since both are used to access the internet, I chose to run both and have a lovely printout which probably tells somebody something.
I am also having problems saving and accessing files from one to the other. The two are talking to each other, but when I go to save I get a message saying "make sure disc is not full or write protected and that file is not in use." I suspect there is some sharing setting that I need to tweak.
Any help gratefully accepted.
  • asiftahir Mar 25, 2009
    I also almost have the same problem. I have a laptop connected to internet through DSL modem. on the other hand I have a desktop and I want share my internet connection on both laptop and desktop.
    You can post message on my forum.
  • Carl Navarro
    Carl Navarro May 11, 2010
    Here are a couple of tips. Post here read here. Start a new topic instead of tacking onto a 10-month old thread.
    The product you need is a WIRELESS ROUTER. You can pick one up for about $40. It plugs into the DSL and sets up a private network between your desktop, laptop, printer, or whatever else you have.
  • D-Link Master
  • 6,487 Answers
You need to make sure first that your laptop is connected to your wireless router's network because that the only way you can use internet access and access file on your laptop using the router.
Posted on Jun 16, 2008
D-link range booster installed on main PC, still
Check your wiring:
Cable-modem (or DSL-modem) <---> WAN-port on Router
LAN-port on router <--> network-port on your desktop computer
Follow the instructions that came with the router,
to access the built-in web-server "inside" the router.
Run the "Wireless Networking Setup Wizard" to configure your wireless network.
Now, try to access your newly-defined network from your laptop.
Jan 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
Apr 29, 2009 | ASUS Wi-Fi@HOME (WIFIG80211G) 802.11g/b...
Help with my wireless router
you have the internet on desktop pc and you want to connect your laptop right?
open control panel select network set up wizzard and follow instructions for shared network.
if you connect dsl to notebook you need to have installed modem device drivers and configured device and done basically everything you had to do on pc,by disconnecting dsl from pc obviosly youre gonna lose the internet.
get your self a wireless router if not already have one , that way you set up pc wired and link laptop via wireless
Jan 09, 2009 | Computers & Internet
My desktop uses a DSL internet connection but my lap top will not pick up the signal from it to connect even when I have it sitting right next to my desktop. If I actually unplug yellow connection cord...
Having your laptop sitting next to your desktop will not let your laptop connect to the DSL link.
You need what's called a Wireless Router. (assuming your laptop has a wireless adapter, if not you'll need a network cable for that.
1. Go to the store, buy a wireless router
2. install router in between your DSL modem and the computer.
3. Plug the WAN port into the DSL modem (cable is usually included with the router)
4. Plug the desktop into the back of one of the ports of the wireless router
5. Run the setup disk
6. For manual configuration of the router you can usually go to: 192.168.0.1 or 192.168.1.1 or 192.168.2.1 depending on the brand)
7. If you don't know anything about networking, let the install disk do all the work.
8. Follow the instructions on what it tells you your configuration is for your wireless network.
9. Go to your laptop, apply said instructions.
10. ???
11. Profit.
Dec 02, 2008 | Acer Aspire 5050-3242 Notebook
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Won't connect to AT&T DSL service
Most desktop computers do not come standard with wireless connectivity, and the 530s is no exception. To connect to the internet, you will need either an ethernet cable to run between the computer and the DSL box, or a wireless card, which can be installed inside your computer, allowing you to access wireless networks.
Jul 20, 2008 | Dell Inspiron 530s Desktop Computer...
Internet via another computer's DSL
Ok so your computer says conencted to wireless network,
Check if the pc is getting a valid ip address follow this Click start>RUN>type CMD>click OK>then type ipconfig you should be getting a 192..x.x.x if you're getting a 169.x.x.x ir means that you're really not connected to your wireless network, if there's a wireless security enable on your network make sure you have the correct key.
Jun 16, 2008 | D-Link DI-514 / DWL-520 Kit...
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
D-Link DI-514 / DWL-520 Kit (di-514/dwl-520-k) Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
