Question about Bosch Classixx WFL 2066 Front Load Washer
My machine does not drain the water out of the drum after each wash
  • Bosch Master
  • 3,463 Answers
You needs to check and clean the filter .
It should be located at the bottom front right of washer behind a flap,unscrew anti-clockwise to remove and clean.
Posted on Nov 10, 2010
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Water in washing machine drum
I shall give you some tips for cleaning the washing machine and clearing the smell
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1182/smelly-washing-machine.html
Oct 19, 2011 | Washing Machines
Water won't drain from washing machine
could be the bearing on your drum
empty the water out and rotate the drum by hand
if it is grinding it will be the bearing
Jun 26, 2010 | Frigidaire ATF6000ES Front Load Washer
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Washing still wet after washing machine cycle. After full cycle the wahing in the machine was still soaking wet
Either the pump is not emptying the machine quickly enough, or the drum is not spinning. This could also be because there is too much water left in the machine. Check that the drain hose is not blocked and that water is draining/pumping out of the machine. A partial blockage will extend the drain period and the machine may not have time to empty the drum...Good luck......Nomess
Apr 18, 2010 | Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool AWN 321 washer continues to drain water out of drum throughout the whole wash and rinse cycles. The consequence of this is the machine continually draws in hot and cold water to achieve the...
This sounds like a siphon condition. Remove the drain hose (the thicker black hose from the back of the machine) out of the wall. Now re-insert it back in only 6" going into the drain. When they go in too far, the drain in your house that prevents odors from coming back out of your drain causes a siphon that pulls the water back out when the washer is filling. Make sure to tie the drain hose down with a tie so it does not pop back out when the washer is draining/ spinning.
Jun 30, 2008 | Whirlpool Washing Machines
Water leaking into drum?
hi it sounds like you have a water valve staying open you will need to find out if it is the hot/cold then replace hope this helps
Mar 12, 2008 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
