Question about Mantis 2-Cycle Tiller
Does not run, will start with starting fluid - Mantis 2-Cycle Tiller
    Champion:
  • 208 Answers
You should never use starting fluid on this model.
Add a couple of ounces of 100% acetone (available at Walmart) to some fresh fuel. Attempt to start for several pulls. Let sit for several minutes and repeat until it sounds like it wants to run.
Then watch this video and do it:
http://www.alamia.us/mantis_parts_s/148.htm
Posted on Feb 20, 2011
My mule will not keep running. Stopped suddenly after good start. Replaced the fuel pump. Still will not keep running. Fires. Then stops. Fires on starting fluid. What could it be?
When you say it fires with starting fluid can you keep it running with the starting fluid or does it just fire while cranking the starter then stop when the key is turned to run if it keeps running with the starting fluid then you still have a pump problem or the filter could be plugged or the carb could be bad but if it'd fuel injection then it might just not getting enough pressure fuel injection takes high pressure
Sep 18, 2017 | Cars & Trucks
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Cub Cadet1045 will not start without using starting fluid. After starting it with SF(starting fluid) it runs fine. It will also crank up on its own after that. After not running for 15/20 minutes, it will...
starting fluid is TERRIBLE for small engines carburetor cleaner is a better solution starting fluid will damage rings and cause compression loss but it sounds like the choke is not working correctly or if it has a primer it is failing
Jun 04, 2013 | Garden
93 toyota pickup 4x4 it will stay running after I turn it on to start it up, it starts up then after a few seconds it kills
if I'm reading this right...
... the engine starts and dies within a few seconds.
... you jumpered the fuel pump test connector and it will keep running.
... you smell fuel after trying to re-start when it dies.
Disconnect the plug to the cold start injector. Even if you have an issue with the engine running then dying after a few seconds after doing this, if you don't smell fuel after disconnecting the cold start injector and try to restart it, the cold start time injector time switch may be failing.
Buy a can of starting fluid and have someone start the engine then spray short bursts of the fluid around all the intake fittings. If spraying the fluid in any particular area keeps the engine running, I'd start looking for leaks around that area.
It does sound like an AFM or COR issue considering it dies after a few seconds, but the fuel smell when trying to restart the engine may be a separate issue that needs corrected / isolated first.it will keep running.
Mar 30, 2013 | Cars & Trucks
1992 saturn sedan will not start if check engine light is off. Will run on starting fluid though?
Replace the fuel filter first and the spark plugs and then try without the starting fluid?
Jun 20, 2012 | 1992 Saturn SL
Turns over and over can hear fuel pump come on will start with starting fluid and runs great but when shut off for a little while wont start again only with starting fluid
If the starting fluid works then you have a fuel pump or a fuel pump relay issue. The fuel pump relay allows the pump to come on for about 2 secs and prime the fuel system. Once the engine starts then the power to the fuel pump runs through the oil pressure circuit.
If the car starts on starting fluid and then continues to run... I would lean toward a fuel pump relay issue. Hope this helps, Good Luck!
Aug 18, 2011 | 1996 Chevrolet Tahoe
No start
if it runs on starting fluid its a fuel problem.. check fuel pressure even if its a couple of pounds off, the vehicle will not run. but using starting fluid may give you the extra poundage you need to make it run . also check vacuum hose at pressure regulator on fuel rail
Aug 02, 2008 | 1991 Buick Regal
Mantis 2-Cycle Tiller Logo
74 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
