Question about Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player
Picture on screen is off set
The picture on my screen is half of one page and half of another i can't find any other noted info on this problem. i cannot access some of my options that i need to reach what can i do?
  • 26 Answers
We can fix this and all other problems with the AVIC N1 N2 N3 Systems.
Please visit www.turbotunes.com for affordable repair service
-Steve
Posted on Apr 06, 2009
Samsung 32 LCD TV; Image horiz size is too large overruns screen L-R; See Details for more info What is the root cause & how can it be corrected? Thanks, Steve
try getting the onscreen menu up and then going to the aspect ratio setting
change that until the picture fits the screen
go -ok then exit
Sep 27, 2015 | Samsung Televison & Video
SONY PFM42B1
Just check - easiest with another tv if you have one that the signal source you are using is not the cause of the dimming. Also check that the voltage supply to the set is at the correct level - unlikely but a slightly lower voltage on the power circuit could dim your picture. The phosphor in a plasmascreen is generally a thin coating inside each of the tiny glass pockets which contain the plasma gas mixture (each of which becomes a pixel when activated). Unless you could open up each one of the pixel pockets and recoat the inside (not recommended) the answer to your question is no. Since the picture is made with phosphor, engineers can accurately predict the geometric decline of the phosphor?s potential brightness. Note that while the brightness declines slowly, the phosphors never actually burn out. Also, note how the rate slows over time. The rate of decline points to a specification called ?Life to Half Brightness? or LTHB. The half life ranges from about 10,000 to 60,000 hours, depending on model, it is about the same as you?d expect in a high-quality, properly calibrated TV or studio monitor.(see attached graph). Here is the link to the user manual for your set if you need it; http://esupport.sony.com/perl/model-documents.pl?mdl=PFM42B1 Check page 97 of the pdf (page 45(GB) of the manual) - it explains the self diagnosis feature. Sorry I couldn't find the details of the resulting flashing light's meaning online - you need to contact sony with the results to find out for sure if your screen is the problem. Hope this helps - sorry if bad news :)
Aug 05, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
I didnt have a picture so i started hitting buttons. Now I have HDMI Settings with two options showing and can'get rid of it
Have you tried using the "Menu" button or "Input" button on the left-hand side of the set to make a selection/change the current selection?
You may also want to try unplugging the set for at least 30 seconds to see if removing power will clear the frozen screen.
Finally, note that three of the four HDMI inputs have notes associated with them in the manual on page 3, the "Part Names" page. See the notes on the right-hand, bottom of the page; items 3, 4, and 5.
Dec 31, 2014 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
How do I send notes to my kitchen printer
You first need to create a new inventory item.
1. Create a standard item in the INVENTORY Maintenance.
2. Call it NOTES and put it in the NONE department.
3. Uncheck all boxes under OPTIONAL INFO, the OPTIONS tab.
4. Click the ADDITIONAL INFO tab, uncheck all boxes but PROMPT DESCRIPTION.
5. Under PRINTERS, add the kitchen printer.
6. Save the inventory item.
7. Go to SETUP, TOUCH SCREEN CONFIGURATION.
8. Click on one of the 16 buttons in middle of page, an unused one. It should turn green.
9. On bottom half of page, set it to a FIXED ITEM.
10. Set caption to KITCHEN NOTES.
11. Check box to display button.
12. Picture can be left blank.
13. In ENTER ITEM NUMBER, type NOTES, the new item you created.
14. Click SAVE AND EXIT.
15. Log out of RPE. When you log back in, you should have a KITCHEN NOTES button. You have a limit of 30 characters. However you can hit button as often as you like to continue your message to kitchen. This should not print on customer's receipt.
B Mattern
sysadmin@ccybernet.com
Aug 29, 2010 | Pc America Restaurant Pro Express
27'' lxi reduced picture
This is a problem with the vertical circuit and can be as simple as poor solder connections within that circuit or defective parts. If you have no experience with soldering or TVs, this should go to a service shop. Expect a parts cost in the $30-$40 range for and IC +/or capacitors. If you'd like to attempt this yourself, please supply the exact make and model so I can post the parts required along with additional instructions. Please note that TVs contain potentially dangerous high voltages even when unplugged.
Thanks,
Dan
Mar 15, 2010 | Televison & Video
D700 Shutter Problem
Did you try to use a different
card?
Jun 27, 2017 | Cameras
Picture within a picture on screen
Click here to find info the user's guide and how to turn close caption OFF. Download all the files and and you should find the info on page #19 but you will need to have the TV remote control or if your TV has a menu/set up button on the front panel, you can try to get to close caption using the channel up/down and volume up/down.
Good Luck.
Oct 10, 2008 | Sony KV-35V35 TV
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player Logo
44 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
