Question about Pool & Spa
How to prime four winds spa pump - Pool & Spa
2 Suggested Answers
  • 77 Answers
SOURCE: my self priming spa pump wont prime
Bleed air from pump by loosening union nut until water emrges, then retighten by hand. good luck
Posted on Aug 19, 2009
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
Hayward super pump won't prime
Priming issues are almost always due to a bad gasket or loose fitting.
  1. Remove the leaf trap lid. Examine the gasket for debris, cuts or folds that might prevent a tight seal.
  2. Remove and examine the winter plugs for proper seal.
  3. Remove, re-tape or putty the threaded fitting directly in from of the pump.
  4. Check all unions, fittings and connections from the skimmer and main drain to the pump.
  5. On rare occasions the impeller may be impacted with debris preventing water flow. Remove the four screws holding the motor to the wet end exposing the impeller and examine it. Hayward impellers are also know to break at the shaft. This will sound like the pump is operating but never pumping water.
  6. If everything looks normal, try pouring water over the entire wet end while priming. This will sometimes allow water to fill a void you missed. The pump will probably loose prime again until the issue is corrected.
Aug 17, 2014 | Pool & Spa
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
How do I prime the pump on my VS500
The pump will prime when you turn on the circuit breaker. There is a prime cycle that will run for a couple of minutes to get all the air out of your spa system before the heater will engage.
Rod
US Parts Center
888-521-6183
Apr 05, 2013 | Pool & Spa
PUMP RUNS A FEW SECONDS THEN CLICKS OFF
Verify that your voltage is correct, then check your amps. It sounds like you have a short in the windings causing the motor to overheat. This usually mean replacement. (the repair would be almost as much as a new motor)
Feb 07, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
Dec 19, 2011 | Sta Rite Pool & Spa
Pump wont run
does it turn freely if not check pump impeller for debris or damage repair or replace if necessary--if good- check motor bearings if not turning may need to be lubed or motor replaced check amp draw if spiked or nothing than possible open winding and may need replacement
Apr 08, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
System error prime pump again. the pump does not
if the pump is not a self priming pump, it is possible that the windings may have burned out. use a hose to prime and then try in the Maint, position.
Oct 16, 2009 | RTO Safety Vacuum Release System - SR-500...
Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Mar 07, 2009 | Pentair Mastertemp Heater
Pool & Spa Logo
197 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
