Question about Canon SPEEDLITE 580EX TTL Flash
Broken Hot Shoe
I have broken the plastic Hot-Shoe on my Canon 580EX Flash. Where can I buy or order a replacement part??
This link gives step-by-step instructions with pictures for replacing the shoe.
http://planetneil.com/tangents/2007/05/31/repairing-the-canon-580ex-hotshoe-foot/
Posted on Jul 19, 2008
How do i nrepair the broken hot shoe of my canon 580EX.? AND WHERE CAN I GET THE PARTS?
I have not dealt with canon spares department, but from dealing with Olympus and other camera vendors, you must find the tel number of their spares department and order the broken part. Usually they don't know the part number, but you can often get them to send a picture or fax an exploded view, so you can match the parts you need.
The foot of my canon 550 which maybe similar, is attached with 4 screws and from memory you have to pop off the window in front too?
You might need a soldering iron too if wires are broken.
Taking apart these flashes there is some safety risk as the capacitors can be hazardous if still charged. If you don't know how to safely discharge the flash capacitor (the very large cylindrical part looking like a can), wait at least a few days after last powering unit and wear rubber gloves.
Camera vendors spares departments have got a lot less friendly to consumers in recent years, as they prefer to deal with repairmen. Sometimes this means you have to have an account or there is minimum cash amount. Be persistant and you can often get through to somebody helpful. try , 1 (866) 481-2569 to start, to try to find the real number you need
Ebay often also has spares, sometimes at outlandish prices.
Good luck.
Jun 10, 2015 | Canon Cameras
I just purchased a Rebel T2i and a 580EX II Speedlight. After approximately 50 flash photos, the speedlight shifts slightly to the rear and it appears the contact between the speedlight and camera...
It would appear to me that the flash was not locked in position and has move back on its mount which would cause the flash to go into complete manual mode or loose complete communications between camera and flash.
I would suggest shutting the camera and flash off remove the flash first unlock the little locking leaver on the bottom. The 580EX and the 580EX II differ in that the 580EX II has a leaver rather then the huge locking screw. Once apart reinsert the flash unit back into the camera hot shoe making sure that the forward edge of the flash mount is seated as deep into the Hot Shoe as possible and lock it into position. It should click into lock position. Biggest thing I have with my "crew" is when there is a flash installed on the camera they pick the camera/flash unit up by the flash that's a real bad thing cause the flash mount is light plastic and it'll ether break, twist or even unlock the flash enough that the camera falls off of the flash. Pick the assembly up with both hands lens and body. I'm not saying you are doing this but when my crew/working associate's do this I'm not happy.
Although that new switch idea is great it also can be unlocked without noticing.
Diagram
Jan 06, 2011 | Canon Speedlite 580EX II TTL Flash
I have a Di622 Nissin Flash, the base is broken. The part that slides into the hot-shoe. Would like a quote on the fix.
i have a Di622 Nissin Flash, the base (hotshoe contact piece that slides in camera) is broke is there anywhere I can order the replacement piece?
Jul 20, 2010 | Nissin Speedlite Di622 TTL Flash for Canon
Broken plastic shoe on flash gun need replacement ?
The foot is less than $10 including shipping and takes 10 minutes at the most to replace. Order from Canon....in North America: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2110&fcategoryid=217&modelid=10514
Apr 12, 2009 | Cameras
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Canon 430 flash
the best will be to take the flash to a canon repair center
you can try to repair it yourself, you will need a peace like this:
http://cgi.ebay.com/CANON-420EX-430EX-580EX-HOT-SHOE-FOOT-LOWEST-INTL-SHIP_W0QQitemZ370071354531QQcmdZViewItem?_trksid=p3286.m20.l1116
Sep 09, 2008 | Canon Speedlite 430EX TTL Flash
Replacement shoe for Sigma EF-500
send it to a sigma agent thay can replace the broken part
Nov 02, 2007 | Sigma EF-500 DG for TTL Flash
Broken hotshoe for 550EX
http://www.uscamera.com/550ex.htm i did the same with my 430ex ordered part from url above. need to do a little soldering though.
Aug 21, 2007 | Canon Speedlite 550EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
403 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
