Question about LG WM2101HW 4.0 cu.ft. Washer
Where is the serial number on the machine? We have a front loading LG washing machine.
  • 441 Answers
When you open the door it should be on a 2" x 3" white sticker around the door opeing
Posted on Nov 09, 2010
LG WaveForce top load washing machine flashes unbalanced on every single load. Even when run completely empty. a single load can take up to 6 hours to complete.Manufacturer nonresponsive. Solutions?
LG issued a recall on certain waveforce washers due to the unbalanced error codes. You may have a washer that is affected. Contact LG at 855-400-4639, and have you model number and serial number at hand to see if you need a software update.
Jan 25, 2016 | LG Washing Machines
Where is the serial number located on my lg top loading high efficiency washing machine
some put a label on the lid if not there look on the back but serial number is usually not important but model sure is
Feb 20, 2015 | LG Washing Machines
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
I have an LG Tromm front load washer. During the spin cycle it sounds like a plane is taking off and now I smell burning. Could anyone tell me what is happening. and what I need to replace in it. ...
It's not the gasket but the bearings at the back of the drum which are going. These can be replaced in some machines where you can split the drum but I'm not sure about LG. You can buy bearing kits by quoting the model number and serial or product number usually found on the inside of the door. This can be a laborious task and depending on how bad the bearings are in the machine an almost impossible task. My advice it's a new machine or check the manufacturers parts guarantee, you might be covered for parts only.
Hope this helps
Sep 17, 2013 | LG WM-2277HW Front Load Washer
It will not power on
Are you sure the outlet has power?
If so, then you may have to replace the control board. You will need to call the parts department with the exact model number and serial number for the current version control board.
Good luck
Jul 11, 2011 | LG WM2487H Front Load Washer
How do I find model number and serial number on LG washer and dryer?
front load washer upper part inside door frame
top load upper right side back
your looking for a metal plate.. it will have the serial number and the model number.
Sep 18, 2010 | LG Washing Machines
Where do I find the serial number on my lg washer
Open the front door on front-loading washers. Look at the upper part of the door frame just above the opening.Look at the right side of the washing machine near the front, upper corner on top-loading washers.Identify the location of the metallic rating plate attached to the frame.Find the serial number by identifying the number that follows the "S/N" printed on the plate.
Jun 12, 2010 | LG WM2301H Washer
Serial Number location on LG WM2016CW
just open the door on your lg and the serial number is on a tag.
May 05, 2009 | LG WM2455 Front Load Washer
Service manual
http://us.lge.com/support/download/search.jhtml
This site should work for what you need. You will need your model number (located inside the front door, be sure you use model number, not serial number) to gain access.
Oct 31, 2008 | LG WM-2277HW Front Load Washer
LG WM2101HW 4.0 cu.ft. Washer Logo
63 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
