Question about Nikon Coolpix 5400 Digital Camera
My camera wont let me load a new card without formatting when i go to continue without formatting it says to turn it off
  • kakima Nov 09, 2010
    Is there a reason why you don't want to format the new card? In general, memory cards should be formatted in the camera before use.
    Brigadier General:
  • 11,967 Answers
If it is truly a new card, then it must be formatted in the camera to operate correctly.
Posted on Nov 09, 2010
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
Dec 24, 2009 | Kodak EasyShare Z612 Digital Camera
Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
Dec 18, 2009 | Kodak EasyShare Z740 Digital Camera
My easyshare camera won`t format my SD card, but says format card, its says continue to I do, and stops formatting instantly, but wont let me take any pictures or anything till its formatted. My computer...
To format the card in the computer card reader would be a way to see if the card can be formatted.
Make sure the little switch is up or in the position to format or write to the card.
If the card can be formatted in a card reader, then the card is okay. But the card should always be formatted in the camera you will use it in. There can be corruption of files when systems are mixed on one card.
Make sure that all the menu settings are at factory default, then set them as you please.
Sep 27, 2009 | Kodak EasyShare CX7530 Digital Camera
My camera wont format card
The card needs to be formatted in the camera, not on the computer. Try going into the camera menu and find "reset"...follow the on-screen instructions.
Sep 08, 2009 | Kodak EasyShare Z740 Digital Camera
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Step four: Ensure the batteries are installed correctly
    Step five: Turn on the camera without the memory card
    3. Wait 15 seconds.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Nikon Coolpix 5400 Digital Camera Logo
27 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
