Question about Kodak Carousel 4400 Slide Projector
The fan has stopped working, and the projector has shut down and will not turn on. The bulb is still OK.
    President:
  • Kodak Master
  • 412 Answers
The thermal fuse behind the lamp module has opened (usually due to a high internal temperature). On some occasions, this is caused by a fan belt failure. Because this involves primary voltage, I would recommend you take the projector to an authorized repair dealer.
Posted on Nov 09, 2010
The projector lamps always burning out. I think, the cooling system does not work?How does the projector work?
Make sure not to shut down the projector after use. Wait until the fan stops. The fan is to cool down the bulb during and after use. Once the fan stops, then you can shut it down.
Feb 29, 2016 | Office Equipment & Supplies
Bulb works, projector turns on, though it immediately shut
check the fan if it works as will as clean the filter.
Aug 18, 2012 | Epson EX31 Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
I have an Infocus IN2102EP projector. It was shutting down after several minutes of use. I contacted InFocus support and they advised to change the bulb. I've changed the bulb and reset the bulb hours. ...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 04, 2011 | InFocus In2102 Projector
Projector heating up and bulb shuts down
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 08, 2010 | Dell 2300MP Multimedia Projector
Keeps turning off
So, Shutting down to protect itself. The error light says it needs service, Cycling power makes it work for a few more minutes, then the Panasonic safety circuit shuts it down. Projector shuts down when bulb life gets to the danger zone, and also when its heat sensor says there is a problem.
So you have a bulb life issue or you have a dirty projector / fan cooling issue??
I say clean it up with some compressed air when it is cool, then check the # of hours the bulb has on it (in the menu).
Lastly brace yourself, the bulb is gonna hurt you :-$
Jun 27, 2010 | Panasonic PT-AX200U Projector
I have a Luxeon v1 that runs for about 1-2 hours and then shuts itself off. The bulb is off but the fan is still running. I am unable to turn off the projector and I have to unplug it from the outlet to...
First of all, DO NOT unplug the unit until the fan stops. The fan should continue to run until the lamp has cooled down completely. This is normal. If the unit is shutting down on its own, perhaps the fan is not working good enough. Check for debris in the fan area and be sure that there is enough ventilation to keep the unit cool. The shutdown may be a safety shutoff because of heat.
Check the fans and update this with what you find.
Dan
Nov 03, 2009 | Luxeon V1 Multimedia Projector
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Optoma H56 - turns off just after start up.
It's not a short, the blub is near the end of it's life ~ the optoma is designed to detect when the blub is about to blow and shuts itself down. Turning the projector upside down or right side up usually only gives you a brief reprieve (some have reported a modest amount of extra time gained) on the blub ~ but in the end it's on it's way out and the projector will shut down again.
Oct 14, 2007 | Optoma H56 Multimedia Projector
Kodak Carousel 4400 Slide Projector Logo
122 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
