Question about Xerox CopyCentre C20 Black and White Copier
Unable to use upper feeder on CopyCentre C20 - Xerox CopyCentre C20 Black and White Copier
    President:
  • 2,072 Answers
Turn the machine off. Disconnect the white cable on the back of the machine. Turn the machine back on let it come to ready.
Turn the machine back off, plug the feeder back on and turn the machine back on.
The machine seems to forget it has the feeder from time to time.
It has to boot up with it unplugged to reset.
Posted on Nov 10, 2010
  • Rick Kasper Nov 12, 2010
    Did this work?
My c-20 copier will not print from glass. prints blank pages. will only print the ones placed on the feeder.
I know this silly, but you put the originals on the opposite end of the glass. I don't mean to insult anyone, but I don't know your experience with this machine.
The fact that it copies thru the feeder, tells me the copier is ok. The doc feeder uses the same optics.
hope this helps
Feb 07, 2011 | Xerox CopyCentre C20 Black and White...
Xerox Copier C20
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 09, 2008 | Xerox CopyCentre C20 Black and White...
Password for the Copycentre C20
Try 0000. That is quite often the default.
Nov 21, 2009 | Xerox CopyCentre C20 Black and White...
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
When I use the automatic document feeder on my xerox copycentre C20 I get a black line running the length of the page. If I make a copy from the glass, one sheet at a time, it is fine. Is there a way to...
You have something on your "**** glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
(Please rate this response as I'm trying to obtain the next level.)
Aug 04, 2009 | Xerox CopyCentre C20 Black and White...
Our copier makes light copies.
Most likely, you need a new toner cartridge, part number 106R01047
Jul 24, 2009 | Xerox CopyCentre C20 Black and White...
XEROX COPYCENTRE C20
u can find manual for this copier at the link below:
www.lostmydrivers.com
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
RX paper tray full
Yep, easy fix. Look into the area where your copies come out, between the paper try and scanner. look towards the upper back and you will see a flag sensor, about 2 inches wide and 1 inch in height. It has come out of the 2 clips it snaps into. Carefuly move it around until you line it up properly then snap it back into the clips it mounts to. You may have to gently squeeze those clips together to hold the flag in place.
That is your problem. Easy one to resolve.
Feb 12, 2008 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
