How do I increase mtu settings TP-Link W8960n Router to run an xbox
5 Suggested Answers
SOURCE: XBox 360 MTU Failed with Router
ive got ur solution right here guys...
go to start - run - type in "regedit" (without parenthises)
press CTRL+F
paste this in and search
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces
if it searches and wont find it then youll have to go folder to folder manually its not hard.
then inside of the interfaces ,
youll see a bunch of giberish numbers and letters. theres are your routers/modems/etc.
just click on each of them until you see in the right colum theres a MTU value, under the Name tab
(note some people have more then 1 MTU value so youll try to have to mess with stuff to find out which one is ur router)
K!
So we finally found our MTU.
right click it and click the decimal button.
then type what u need it to be ^_^ hope this helps..
OH btw
this was all on a Windows XP idk if it works with all comps.
and once u change the value.
restart ur comp to make the effects take place
Posted on Sep 29, 2008
kakee
  • 1269 Answers
SOURCE: Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Posted on Jun 02, 2009
  • 173 Answers
SOURCE: i need help changing the MTU settings on a D-link DI-624 router.
you have to enable wi fi in your router for that you need to access it.
Coonect your router to 1 computer with ethernet cable then access following link
http://192.168.0.1
or
http://192.168.1.1
then type username as "admin" and password as "admin" or blank or "password"
Then go to wirelesss and enable wi fi .
Posted on Jun 17, 2009
  • 35 Answers
SOURCE: I need to increase my MTU settings on my router for Xbox LIVE.
You can do that by configuring your router. Look for the default ip address of yoour router, it can be found in your router's manual. After you found it, run internet explorer and type in your ip address (ex. 192.168.10.1). There you o just enter your username and password and your on your way to the configuration process. Go to internet setup and under DHCP Internet Connection Type you can change MTU there. Just give it a try...
Posted on Jun 21, 2009
I can't install
You need to read the manual here.
http://www.tp-link.com/Resources/document/TD-W8960N_V3_User_Guide.pdf
It needs power and the router plugging into the line via the line socket.
A Ethernet cable needs to plugged into one of the WAN ports to configure the router, the other end needed to be plugged into a pc.
Mar 14, 2015 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Set up a wireless modem
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 19, 2012 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Computers & Internet Logo
277 people viewed this question
Alun Cox
David Payne
David Payne
