Question about Ovens
My Indesit FM20KIXGB Oven has started to make a loud vibrating type noise when the oven is on. The oven still heats up though. What could be causing this and is it an easy fix.
5 Suggested Answers
SOURCE: Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
Posted on May 16, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
SOURCE: Need instruction manual for operating Indesit Automatic Oven
I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
Posted on Apr 22, 2010
Flavel milano e50 cooker the oven is.making a very loud rattling noise. But it is still working. Any ideas what the problem is.
It's not a fan oven, so there's no moving parts.
It must be a panel or component (such as a shelf) vibrating in the heat.
When it's cold have a good look at the inside & see if there are any screw heads you can tighten & any of the components which can be pushed tighter.
Also check the thermostat probes to make sure that they're not vibrating against the side or top of the oven.?
Best of luck
Mar 13, 2018 | Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Kitchenaid superba oven
What is the model number?
Jun 19, 2013 | Ovens
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Indesit fde20 main oven wont heat up
Oct 23, 2009 | Ovens
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
Turbo Chef hi speed oven prblem with 2004 model very loud fan
is this a c3 or a tornado oven.there are afew causes for that type of noise but are diffrent for each type,regards les
May 08, 2009 | TurboChef C3 Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
