Question about Carrier 38CKC060 Air Conditioner
Cools for a while ... keeps running but stops cooling.
Carrier Model 38CKC060370 About two years old and has worked very well during past two summers. Now ... with thermostat set for about 69 deg. ... system runs for about 1/2 hr. and puts out cool air at about. 65 deg at vent ...drops inside temp from high 70s to low>mid 70s ... then stops producing cool air put condenser and fan keeps running. System has to be turned off for a while and started up again to continue producing cool air.
Service company said that condenser was icing up due to stuck bypass ?? They said everything now looks good ... PG&E said power consumption is normal ... but system still only cools for a short while and will not chill house down to or below about 73 deg.
    Novelist:
    Champion:
  • 230 Answers
If the refrigerant has been accurately charged and diagnosed, I would look for an air restriction. Check your filter first of all. It sounds like it may still be trying to freeze up. Make sure all the vents are at least a little open and the return grill is not blocked. In the Rocky mountain region we like to see around 44- 50 deg. at the vents. 65 would tell us that everything is not ok.
Posted on Jun 17, 2008
How do I find the part # for a compressor wiring harness for my Carrier model 38CKC060370 Air Conditioner?
carrier does not list a part number for this unit on a wiring harness. usually have to replace wires that are bad.
Mar 14, 2015 | Carrier Heating & Cooling
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Carrier 38CKC060370 The fan seems to work but air is not cold.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 03, 2011 | Carrier 38CKC060 Air Conditioner
Can i Use 5w-50 oil in a1999 Cavalier in the Summer or will it Hurt it Motor that is
You can drive the car during the summer, your radiator cools the engine. Today's cars are not air-cooled engines, they are water-cooled.
Mar 20, 2011 | 1999 Chevrolet Cavalier
How much Freon R-22 usually require to fill up an empty Air Conditioner. My AC model number is 38CKC060370. Thanks
On the manufactures tag, it will list the pounds and ounces, that is required, this usually includes, about 25 feet of line, usually add 1 1/2 ounces per foot past that.
Sincerely,
Paul
PS. It is best to weight the charge in with electronic scales designed for this,
May 10, 2010 | Carrier 38CKC036 Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
I've had to replace the blower motor on an old GE electric furnace three times in the past year. The first time the motor just stopped working. So I replaced it with an A.O. Smith motor for the summer. It...
This is definately not a good thing. This unit is a safety hazard to say the least. Check for recalls by reporting it to the consumer product safety.
Jun 12, 2009 | Heating & Cooling
Hunter thermastat, model 44860 not working
Is the compressor running? is the outside unit clean and free from debris? does this unit work in the heating mode during the winter, and is it still capable of that now.
Jun 01, 2009 | Ruud UAMB Air Conditioner
Carrier thermostat
I hate to say it but Ive had trouble with Carrier's Tstats doing similar improper things. Unfortunatly the only repair is going to be replacement of the whole tstat. I recommend Honeywell's FocusPRO or VisionPRO tstat. Ive yet to have one fail and they have a 5yr warranty if they ever do.
Nov 25, 2007 | Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
648 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
