Question about Espresso RMI La Cimbali Espresso Machine
Hi there The temperature light on my la cimbali domus is not coming on. The machine is not heating, so guessing it is the thermastat? Any ideas how to fix it.
    Master:
  • Espresso RMI Master
  • 595 Answers
Call your vendor or cimbali.com for current contacts
youtube; ukeboy57
Posted on Oct 03, 2017
bunnydawg
  • 5158 Answers
SOURCE: hi, I need to download or buy an operation manual for La Cimbali
http://www.home-barista.com/espresso-machines/la-cimbali-m30-classic-manual-i-have-got-it-pdf-t6127.html
parts diagram there too
Posted on Mar 22, 2009
whytfang
  • 170 Answers
SOURCE: la cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
Posted on May 20, 2009
  • 18 Answers
SOURCE: Can you turn off one of the left or right sides on
1-Cover the buttons on offending side (paper and 1 min to do)
2-Reprogram one side to give it a short dose. (5 mins to do)
3-remove power to group valve (screwdriver and 20 mins to do)
Note if you do remove the power, please leave a note for the crew as they will probably call a technician in to 'repair' it again.
Posted on Feb 10, 2010
espressonist
  • 1711 Answers
SOURCE: La Cimbali Junior has no output at the grouphead.
Their are four posible reasons for above problem as follows.
First the Vibarating pump not creating pressure, usaly if here the sound it is pressing but not always. You can loose the pipe nut after the pump to see if you have any pressure after you press the coffee button. Be carefull with the water leaking.
Second the coffee solenoid valve that is on the grouphead might be stuck from dry coffee, it can be removed and cleaned with hot water and a wire brush.
Third the coffee group shower and inside round dish might also blocked from dry coffee, remove it and clean it.
Finnaly the more difficult problem might be that heat excanger that is bettween the headgroup and boiler is full off scale. So you must remove group and clean both group and heat excanger and the copper pipes to them.
This problem is the more difficult to be performed however is the most posible.
Good luck,
Remeber to vote for this answer.
Posted on Mar 08, 2010
EsWorld
  • 1618 Answers
SOURCE: La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Hold down the stop button for about 8-10 seconds you will hear a faint beeping, then press button to program when you get desired volume press stop button, when done programming press stop button.
Posted on May 20, 2010
Looking for a cimbali boiler gasket (domus dosatron)(home machine)
You should be able to get a gasket from your vendor or at least from Cimbali (Italy), or nearby Cimbali rep. (I'm assuming you have tried to do this since it's now 2018.) If you haven't located a part or it's not available anymore then check with Amazon.com as they carry many similar parts. But if your really stuck then you might try a "High Temperature Gasket maker" We use this on the coffee roaster which is heated well beyond the boiling water temperatures found in a boiler. You should be able to get a tube or cartridge from NAPA or any car supply store as they use it for the engine block seal. It's silicone based so okay to use on a boiler. Just clean area and apply a continuous bead around the rim. Sure to surround the bolt (studs) area and continue till you connect with the beginning bead. Carefully lower the cover plate and hand tighten to seal and press some of the chalking flat. But DON'T tighten it all the way down as you want about a 1/16th spacing between the rim and plate. Allow the gasket to dry (cure) for the recommended time then once cured tighten down the cover . You should not see any gasket material oozing out, which means the gasket has not cured. Stop and let it continue to cure (next day) Tighten again and test for leaks.
* You can also try to use a gasket sheet. Plce the cover plate on sheet and draw outline of plate on sheet. Cut out and use a hole punch for the studs. (this is probably the fastest and cleanest method. But you must have steady hands to cut the gasket to fit.
Aloha, ukeboy57 (yourtube)
Feb 04, 2013 | Espresso RMI La Cimbali Espresso Machine
I HAVE A LACIMBALI M53 THAT IS NEW & HAS ONLY
Hi. Could be pressure switch or vaccum valve. To check If the vaccum valve is faulty, try leaving the steam taps open while it is heating up. If it heats up normaly like it supose to than you vaccum valve is stuck. Shouldn't take too long. If it doesn't heat up fast but still heats then that could be element. If it doesn't heat then your pressure switch is faulty. Dazza
Sep 23, 2011 | Espresso RMI La Cimbali Espresso Machine
Hi everyone just wobdering what would be a
It is very rare to find a cimbali m21 junior 2nd hand, for a cheaper price. I understand 2k is a high end price for it depending on the condition of the machine. If it is in top condition, you're getting a steal, however if not then I would try to drop the price by $500.
Mar 17, 2010 | Espresso RMI La Cimbali Espresso Machine
I have a La Cimbali Domus classic servicing required
check cimbali.com for current contacts.
youtube; ukeboy57
Nov 10, 2009 | Espresso RMI La Cimbali Espresso Machine
It seems that the pump was stressed when the machine was heating
The level probe is calling for water which is not getting into the boiler.
Oct 15, 2009 | Espresso RMI La Cimbali Espresso Machine
Hi, I have an old model la cimbali p/tre espresso machine. It has connections for gas but I,ve no idea how to set it up, any ideas anyone??
When it comes to gas connections on the espresso machiones I will usually tell my clients to take it to their heating(furnace) expert, because if it is set wrong you can burn down your place.
Jun 09, 2009 | Espresso RMI La Cimbali Espresso Machine
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
May 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
105 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
