Question about Canon PIXMA MP130 All-In-One InkJet Printer
MP130 - paper not feeding properly and causing a darn mess!!!
Please help me with my problem y'all
when I'm attempting to print , the paper doesn't feed properly and gets all screwed up in the process. some times it gets stuck and i'll get a 'paper jam' message on the screen.
what do i need to do guys?
  • 71 Answers
Hello Dear,
There must be something obstructing the Auto Sheet Feed Assembly, you need to clean the paper path, use a vacuum cleaner or look deep into it if you can find something there if the problem persists you should take your printer to the service center and get it serviced.
Warm Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 17, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Paper won't feed through to the printing area
If when you mash print and the paper doesn't move through to be printed on it may be because you don;t have the paper inserted properly or maybe someone jammed your printer and tried to unjam it the wrong way and didn't tell you....hope it helps
Nov 16, 2011 | Office Equipment & Supplies
Paper feed wont take paper to print gets crinkled and wont print
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
When i go to print the printer starts but doesnt take the paper
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Nov 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Printer keeps on jamming paper
Dear all,
I will try to help you. Paper jam error may be caused by some possibilities. So, please notice this indication:
  • If the printer status is READY immediately after Power ON then Paper Jam Error message appears while feeding the paper: Sheet Feeder Unit is faulty or any other material (such as broken paper) present inside paper path blocking paper end to reach paper feed sensor.
  • If Paper Jam Error messages appears immediately after Power ON: Paper feed sensor or logic board is faulty
Corrective action:
  • Remove the material from paper path
  • Replace Sheet Feeder Unit
  • Replace Paper Feed Sensor / Logic Board
Please rate me as Fixya if you find this useful for you. Thanks.
Source:
Canon Inkjet Printer Forum
Re
Sep 01, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Paper Feed is Jamming
unplug the power cable and the usb cable from the back..........press the power buton for 20 sec........its to release the static from the printer...replug all the cables......printer would work properly now
May 22, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
215 people viewed this question
old marine
old marine
