Question about Dryers
Hello, My name is Eric and have some issues w our dryer. #1 The dryer not working well i believe due to the vent duct/hose didn't seem to be properly done or sized in the back and there is really a poor poor seal on the back of the dryer and going into the floor. #2 There doesn't appear to be lent in the hose so wondering how to clean lent out of the back i guess. #3 Came home and my wife had attempted to take the back off inside the dryer in what she believed was to clean out lent. She had heard to do this second hand. long story short what looks liked a wheel in the back came off its track. A chop stick was used to prop the wheel back up into place to put the screws back. At this point it was decided to stop and put everything back until consulting someone. * A pieced of the cop stick broke off and fell to the bottom of the inside of the dryer. I turned the dryer on for a minute and observed that overheated hair dryer smell. I know believe that the piece of wood is a fire hazard and i need to address the vent hose and where should I be cleaning lent out and how often beside from the lent screen. Thank you for your attention to this email and any assistance you could provide me. Eric Schmidt 617-549-4707 ericfrombeantown@yahoo.com
    President:
  • 1,891 Answers
Hi Eric i thnk i understand . let me say this i have 2 brothers in the appliance service"s and my wife say's if you don"t get this fixed I'm going to call one of them .. ( get the message ) now back to your problem . the vent that is on the back of the dryer needs to be cleaned at least once a year and so does the inside of the dryer . this prvents lint fires and will save mone on the drying and the clothes . so the stick that holds the wheel . ?? I think you ar talking about the belt idler not kinwing the brand or model # if the belt is broken the idler will not tenson . you may need to clean out the dry and replace the belt and idler . and problem solved and then next year doo it again . like getting ready for spring cleaning .. hope this has helped mm . feed backk pls . and brand & model # pls ..
Posted on Nov 10, 2010
Electric dryer duct fire
I think this question must have been misclassified, as it states that this is regarding a Problem with Whirlpool Cabrio WTW6600SBT Top Load Washer. I will assume this is about your dryer. Dryer fires are not as uncommon as most would believe. It sounds like you were utilizing the nylon or plastic dryer vent hose. The lint in your dryer that accumulates can catch fire after years of use. A good dryer vent cleaning will cover your vent duct from the wall to the vent exit outside the home. You should have this cleaned by a professional and have an internal dryer cleaning conducted. If funds are tight, you can do this yourself by pulling the dryer out and running the vacuum cleaner extension into the dryer vent opening after you remove the melted hose. Just be careful when pushing the hose extension up the exhaust as some models will have a heating element in line. If you feel any resistance, that is when you stop pushing the hose in and just suck any lint you can from that point. This is a good start, but a good full internal cleaning of your dryer is warranted. Make sure you unplug the dryer before attempting any cleaning or servicing. Safety first!
Feb 19, 2014 | Dryers
Hello I have a Kenmore gas dryer model# 1107282210 and the dyer seems to give off a little heat but then I it will stop giving of heat and the clothes will take very long time to dry. Now I cleaned the...
HI, Check the following to address this issue further.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task. The blower housing should be disassembled, and cleaned in this case.
2. Thermostat(Secondary Cause)- Highly unlikely in your case, but possible
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 17, 2009 | Kenmore 73952 Gas Dryer
Dryer takes 4-5 hours todry clothes dryer seems hot just not drying
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
Dec 08, 2009 | GE Dryers
Dryer is not drying. Lint is not collecting on
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust.
However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. With a clog comes condensation and longer dry times. The dryer will continue to run inefficiently and cause the heating circuits to work harder and overheat. This will eventually lead to a failure of the heating circuits. If you are seeing condensation inside the dryer, it is strongly recommended the you inspect and clean the dryer exhaust vent hose. You should repeat this a couple of times a year to ensure it remains obstruction free.
The most frequent causes of dryer vent clogs comes from the following:
1. Ducting that runs in an upward direction in homes that have an attic exhaust. This is a stupid design that gravity will always win. When the dryer shuts offf, anything left in the vent will fall down the ducting to the base of the wall and accumulate. Over time, this forms a clog.
2. Ducting that runs under the home in a crawl space. If not correctly hung from the rafters, the ducting will develop sags causing choke points where lint can accumulate. Leaving it on the ground is not the answer, either. This gives opportunity for rodents to possibly chew through it. This will cause leaks which exhausts warm moist air under your home resulting in mold and mildew.
3. Using plastic dryer vent hose. This type of hose is not recommended because it kinks easily and can get crushed, causing an obstruction where lint can clog. Rodents can also chew through it easily. Pushing the dryer up against the wall and crushing the hose is a common cause. Use the semi-rigid metal type ducting that resists crushing, kinks and rodent infestation.
4. Rodents. Mice love lint. If given the access to it, they will build inside the dryer vent hose which provides a nice warm place to live with lots of bedding material. Make sure you exhaust vent on the exterior of your home is about 12 inches from the ground.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not become clogged.
6. Excessively long vent hose. The rule of thumb when it comes to dryer vent ducting is: The SHORTER and STRAIGHTER the run, the BETTER. Excessively long dryer vent hoses will clog due to the fact that the blower fan is not able to push all the air and lint all the way to the exhaust.
7. Kinked, Excessively Bent, or Crushed vent hoses. If the vent has any choke points due to kinks, bends, or gets crushed behind the dryer, you will develop ponts where the exhaust vent will clog.
The following link may also help in providing some basic guidance on how to install dryer vent hose:
http://www.fixya.com/support/r389357-dryer_ducting_installation_tips
I know it may seem that I'm beating this point to death, but it is important to provide good air flow for your dryer. The number one cause of dryer failures and house fires comes from poorly maintained and poorly installed ventilation ducting.
If you have any questions, please let me know. I hope you find this information helpful.
Sep 07, 2009 | Dryers
Taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
1. Venting
2. Thermostat
Aug 21, 2009 | LG Dryers
The lint screen does not capture lint. The lint
To dispell a common myth. There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted through the dryer vent exhaust ducting along with the moisture from your clothing as it dries. If the exhaust vent remains unobstructed, all the air and lint will be blown out the end of the dryer vent exhaust. However, if the air meets any resistance from kinks, excessive bends, or sags, moisture will build up inside the dryer vent exhaust causing the lint to stick to the interior walls of the vent hose. Over time this lint builds up and forms a clog. It is strongly recommended to have the exhaust vent hose checked and/or cleaned a couple of times a year to ensure it remains obstruction free.
5. Exhaust vent screens. I know there are many types of exhaust vents on the market that you can purchase that have screens on them to prevent birds and rodents from entering them. The screen can actually become and obstruction, though. The smaller the opening, the more resistance the blower fan meets and lint will clog at the end of the exhaust. If you chose to use a protected exhaust vent, the ones with louvers work better. You will still need to periodically check the ensure it does not becoe clogged.
If you have any questions, pleae let me know. I hope you find this information helpful.
Aug 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Clothes Not Drying well
1. Venting
2. Thermostat
Jul 31, 2009 | Whirlpool Dryers
It takes three cycles to dry clothes, andthere is heat?
The most likely cause is poor airflow. This may be due to a clogged lint screen (should be cleaned after each load) or a clogged vent. Run the dryer empty and feel the airflow from the vent outlet (where the vent exits the house). If there isn't a good strong flow of air, remove the duct where it attaches to the dryer and check for flow right at the dryer. If there still isn't good flow you may have a bad blower, but chances are the duct is clogged with lint. If it's the white plastic flexible duct or the corrugated metal kind you should replace it with solid 4-inch vent pipe. This will give the best airflow and the smooth walls won't promote lint buildup.
Jan 26, 2009 | Kenmore 22422 Top Load Washer
Dryer not completely drying clothes.
Cleaning the lint trap of the dryer may is not enough in some cases. I suspect you may have a problem with the vent ducting that extends from the the exhaust of the dryer to where it exits your home. The majority of dryer heat realted problems are due to poor ventilation and clogged vents. I dryer left in this condition will overheat to the point of failure. Not to mention, this creates a fire hazard and a habitat for rodents.
A simple test to determine if you have a dryer ventilation problems is to remove the vent hose from the back of the dryer and attempt to dry a load WITHOUT the vent hose attached. The air exiting the back of the dryer should be warm and forceful. If the clothes dry normally, then you need to inspect your vent ducting from where it enters the wall, to where it exits the home.
If the air flow is weak and your clothes still take a long time to dry, then you need to inspect the INTERIOR ducting of the dryer. Namely, the air blower housing. I suspect you'll find your clothes will dry better with the vent hose removed. Since it dried normally BEFORE you moved, and now it doesn't, you need to take a serious look at where the vent exhausts to. If the ducting runs through and attic or crawl splace they typically development sags, kinks and can clog. The rule of thumb when it comes to ducting: the SHORTER and STRAIGHTER, the better. Every bend you put into a dryer vent creates resistance to air flow, makes the dryer blower fan work harder and creates choke points where lint can accumulate and clog. Perform this simple prelimnary check and let me know what you find. I hope you find this advice helpful.
PS Do not run your dryer for extended periods of time without the exhaust hose attached. This will add humidity to your home and potential mildew. One load should be enough to determine if you have a problem. Don't run it this way as a normal everyday routine.
Sep 08, 2008 | Whirlpool LER4634J Electric Dryer
How can I connect my dryer to the vent without crimping the hose? Whenever I connect the hose and push the dryer to the wall, the hose gets holes in it...
The dryer should not be pushed all the way against the wall. For the ventilation to properly work, you should leave about a one foot space between the back of the dryer and the wall. Using 90 degree elbows on the dryer and wall can also eliminate crimping. Also, it is strongly recommended that use use the semi-rigid metal type vent hose ducting. It is not that expensive and comes in adjustable lengths. The semi-rigid ducting is recommended by most builders and it resists crimping and rodent damage. If you continue to use a dryer with the exhaust vent clogged it will lead to eventual heating circuit failure due to overheating. If you have any questions, please post back and let me know. I hope this helps answer some of your questions.
NOTE: If you purchase semi-rigid ducting, make sure you purchased the hose clamps that go with it. This will prevent the hose from slipping off the connection points.
Jun 15, 2008 | Dryers
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
