Question about Whirlpool (ET1MTKXKQ) Top Freezer Refrigerator
When the motor starts their is a rattle noise..When I looked in the back I noticed the fan blade had some play in it could that be the problem..
  • 316 Answers
The shaft of the condenser fan motor will have some play in it, meaing if you are looking at it from the side, along the plane of the fan rotation, it will float to and from the motor itself, or left and right as you look at it from the side. You can isolate the noise by unplugging the refrigerator no less than 5 minutes, a minimum of 5 minutes and for at least 5 minutes. Before you plug the appliance back into the outlet, grab and hold onto the condenser fan blade, it will only be for a few seconds, and the motor is not strong enough that the blade will be ripped out of your hands. If you prefer, you can hold the blades in place by holding a screwdriver in between the blades instead. Plug the unit in, and if you still hear this rattle noise, its the compressor, not the fan motor. If you dont hear the noise, remove the screwdriver between the blades, and listen for the refrigerator noise as the fan motor starts up. If it made the noise then check for any obstructions to the fan blades, check that the three screws that secure the motor are tight, if they are loose, the fan will bounce. if they are tight, you probably have a bad condenser fan motor
Posted on Nov 09, 2010
How to repair exhaust fan rattle?
You can look at fan closely and see if there is a set screw holding the fan to the shaft. It could be loose causing the rattle. If that is not the problem then see if the shaft has a lot of play in it. It could be worn out and allowing the fan to rattle. If that is the case then replace the fan
Apr 26, 2014 | Bosch HBL 642AUC Electric Single Oven
2004 chevy cavalier/ a noise suddely became noticeable coming from near the fan or ductwork under the dash.It sounds as if the fan blades are striking something and also sounds similar to static . It...
My car's glovebox door/trim was rattleing makeing a static noise. I had a friend push up on the trim while it was making the sound, and it stopped, so I just jammed a small wad of tissue up between the trim, and that solved it for the time being. Funny thing tho, after I had my tires balanced, the noise went away never to return. You could have a faulty blower motor tho, if the tissue don't work, or you can't stop it by applying pressure to the trim, look into blower motor replacement.
Dec 16, 2013 | Cars & Trucks
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
Crossley Dryer is making a lot of noise. I opened it up to have a look and it seems that the noise is coming from the plastic rotary fan blade. The blade has some play in it where it sits on the motor...
The blower wheel is replaced as one piece and not the individual blades.
The part number for the blower wheel is 31001317 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Gene..OldTech2332
Aug 20, 2011 | Crosley CDE6000 Electric Dryer
Fan makes a terrible rattling noise
The fan blade may have come loose from the shaft or the fan motor bearings are shot. Repair is accomplished by replacing the blade or motor. If the fan is not operating correctly the magnetron will star to overheat and the oven will shut down.
Jun 21, 2010 | GE Microwave Ovens
JennAir JFC2087HRS makes creaking noises like an old door or someone's stomach growling all day. Now noticed that ice maker not working. Suggestions on how to fix?
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Apr 01, 2010 | Jenn-Air JFC2087HRS Side by Side...
Noises
Now this is a broad complaint!! LOL! Where do we start? What does the noise sound like? If it sounds like a bird chirping, it's your evap fan motor. If it sounds like somethings hitting the fan blade, your unit's frozen up with ice and needs to defrosted COMPLETELY and a new defrost system replaced. Call us and we'll be sure to ge the right parts out to you right away asap so you can get this unit back up and running again! We look forward to hearing from you and hope to be able to work with you more.
Sep 10, 2009 | Whirlpool GC5SHEXN Side by Side...
The fan makes a very loud noise
the fan blade may be loose on the motor shaft there is a set screw on the blade center you can tighten (it needs to be very snug)
Aug 22, 2009 | Kenmore 51841 Kitchen Hood
Amana bottom refrigerater
huthy, the fact that it's lasting 15 to 20 seconds leads me to believe that it could be one of the fan blades hitting. The valve springs on the compresser would make more of a clunk-clunk noise and wouldn't last that long. The evaporator fan in the freezer compartment has a grille that will snap on and off, clip on the bottom and tabs on the side. See if you can remove the grill and check to see if there is any ice build up around the evap. fan. The other fan, condensor is in back by the compressor, it could be hitting on the shroud upon start up or shut down. Check these things first and post back...Catriver
Mar 20, 2007 | Amana ABB1927DE Bottom Freezer...
Whirlpool (ET1MTKXKQ) Top Freezer Refrigerator Logo
282 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
