Question about Microsoft Xbox 360 Elite Console
Audio has a echo effect - Microsoft Xbox 360 Elite Console
Now this can be caused by one of two things,
1. The settings on you TV are not set up correctly, Depending on your TV, the audio settings in the menu may have an option for "equalizer" or "sound mode" your best bet would be to have a play around with these settings whilst playing constant music etc.
2. The connection between your xbox and your TV are not propally connected, remove the cabling and blow any dust away and reinsert the cables.
One way you can test whether its your xbox or yout TV, could be to try the console on another television setup.
Good Luck!!
Posted on Nov 09, 2010
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
Very bad echo, on my NEW Acer laptop 8730G-6945
I had this problem for months - I finally figured it out on my own...
Go to your RealTek HD Audio Manager (this is either a red speaker icon in the bottom right hand corner or if you go to 'control panel, sounds speak and audio devices, realtek hd sound effect manager)
once you have the window open, under 'sound effect, go to environment and to the right of the drop down menu, click 'RESET'.
After months of trying to fix this issue, this fixed it for me!!! I hope it does for you too!
Feb 15, 2010 | Acer 90.00012.30B Computer Speakers
My eee pc 105ha audio has a very discernible echo which makes speech almost incomprehensible and gives a ballpark like quality to music.This is unaccepatble. Will the maker take it back?
I had the same problem. Easy to fix:
Start, Control Panel, open Realteck Audio panel and change teh sound effect to none. Mine was set to Auditorium and had a nast echo.
Jan 05, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do get rid of echo on sound from speakers?
When you say echo, are you meaning sound coming from your mic echoing thru the speakers or a sound like your in a bathroom on all audio.
If you are referring to the mic issue, then open your volume control and make sure that MIC is muted in playback setttings
If you are refering to bathroom sound on everything , it is called a "environmental setting" and in in your sound cards software setup, like their version of the volume control or some other application they have installed for you to configure your card. Just locate the "environmental" setting and disable it / set it to none.
Sep 25, 2009 | Computers & Internet
All sounds on my computer sound like they're in an echo chamber
I had this problem. I right clicked on the speaker icon at the bottom right hand corner of the screen, selected playback devices, left clicked to highlight the 'speakers' (realtek in my case) then clicked properties in the lower right of the open window, clicked on the enhancements tab, and found that my sound effect properties had been changed to auditorium. I clicked the selection arrow and changed the enhancements to 'none'. Oh happy day! No more echo.
Dec 14, 2008 | JBL CREATURE II Computer Speakers
Echo effect when viewing movies/tv
Salutations robert42,
Usually echo effects could be the cause of some type of simulated surround or digital processing effects. Its more noticeable with some television broadcasts then others. I would try and deactivate any processing effects and see if this improves your experience.
Hope this helps.
Jon
Go Ahead. Use Us.
Jul 10, 2008 | Audio Players & Recorders
Have an echo in the speaker system
OK, What is the speaker connected to ?
Is this a PC with a fancy audio card and software ?
Have you activated any fancy special DSP effects
(such as echo, reverb or concert hall effects)
within the audio card settings or software applications ?
DO you have a microphone attached (internal or external)
that is causing feedback?
do you here a howl or a whistle sometimes, when the speakers
get closer to the PC?
Check the Windows Volume Control, both record and playback.
If there is a microphone setting, mute it.
Hope this gets you started, otherwise give us
more info
Martin
Apr 24, 2008 | Computers & Internet
The speakers for the computer sound high pitched and echoing
Some audio cards have special functions. Check the control panel for an icon that may relate -- for example, Creative Labs adds an "Audio HQ" icon to the control panel. One of the icons that Audio HQ presents is called "EAX Control Panel". There it is possible to set all sorts of audio effects, including reverb (echo).
Even if you do not have a Creative Labs card, you may still have "EAX" or something similar. Poke around the control panel to see if there is anything that looks like it might have something to do with audio.
Mar 05, 2008 | Computers & Internet
Microsoft Xbox 360 Elite Console Logo
53 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
